Whisteling noice from pan? only when engine cold, can't find answer??
Old Nov 4, 2002 | 05:34 AM
Bjorn's Avatar
Car: 86-IROC Z28
Engine: 327
Transmission: 700 R4
Hello.
I can't find answer on this with search...
So, I have just put together my 331 and it is running fine so far with good oil pressure, temp etc. but when I start it (cold) it makes this whistling sound that I cannot figure out.
The best I can describe it is like having Tweety the cartoon in there until it warms up..
I have ruled out v-belts and such and I hear it best from listening by the oil pan area, but one can also hear it pretty well from 15 feet away. It continues for a couple of minutes until it graduately dissapears. What can it be?
I am thinking oil pump, but what do I know...
The engine has new oil pump, (hi-vol) rings/bearings/cam/lifters/injectors and is also balanced/bored 030. It has a Pete J. gear drive.
Behind is a 700 R4 w. higher stall conv. (origin unknown)
Thanks.
/Bjorn
Old Nov 4, 2002 | 07:03 AM
ede's Avatar
ede
i doubt if it's anything internal. i'd be looking at belts, try removing them and starting it, or the air being sucked in the TB.
jklein337
Sep 19, 2018 06:23 PM
Caspar
Jun 19, 2016 11:19 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
