Will not turn Over
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Will not turn Over
Well I just finished my cam swap to the Hot cam, as I was starting the car to set the timing it ran a little and then started it up again and it ran a little being I think I had the distributor a tooth off. SO when I got it all back to gether it would not turn over. Everything Comes on Fuel pump...lights.......Do you think in the process I just had a freak problem and blew a fuseable link on the started?????
Brian
Brian
83 Crossfire TA
Sep 8, 2015 12:06 PM
