Brakes and Idle
Old Nov 4, 2002 | 08:59 PM
speedfreak85's Avatar
Brakes and Idle
For some reason, when I push my brakes with the car in park, my idle will raise slightly. Just wondering why this is? Thanks.
Old Nov 4, 2002 | 10:04 PM
Vader's Avatar
Your brake power booster uses vacuum to assist the foot pedal. When you apply the brakes, some of the vacuum from the reservoir (large black drum behind the master cylinder) is bled off to assist the braking. The engine vacuum is used to replace the vacuum, so th edrop in vacuum is also experienced by the intake manifold. If the power booster allows too much air or requires too much vacuum, the drop in vacuum will act like a small vacuum leak and raise the idle slightly. It may be normal on a car with a smaller engine, but shouldn't normally occur on a V-8 or larger 6. If it does, it can be a sign of the brake booster failing.
Later,
Vader
All my life I've been searching for something. Something never comes - never leads to nothing...
Old Nov 4, 2002 | 11:43 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
So if it happens on our v8's its not a good sign? Mine did that awhile back. It seemed to stop after I replaced all my vac. hoses...
Justin
Street Lethal
Apr 30, 2019 12:14 PM
jklein337
Sep 19, 2018 06:23 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
