very low oil pressure
Old Nov 5, 2002 | 05:17 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
latly my 89 formula lo3 (305 tbi) has been running with very low oil pressure at idle not much more then 15 lbs any suggestions as to what can be causing this and what can be done to fix it.
Old Nov 5, 2002 | 05:22 PM
ede's Avatar
ede
screw a mechanical gauge in the block and see what you really have 10psi per 1000 rpm is considered acceptable and normal.
Old Nov 5, 2002 | 05:34 PM
jd13's Avatar
If it was running higher, than it could be your oil sending unit. Mine went bad less than a month ago. Replaced it and just like normal.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
