Aluminum parts, why so expensive??
Car: 99 Formula
Axle/Gears: 342
I was just thinking, heads for instance to have them in aluminum are quite a bit more. Goes for other parts as well.
Is this because it's harder to make? or because there is more demand for them?
Even in raw form, alumnium costs more than iron....(and gold costs even more ye). Add to that the smelting process to make the alloys and then the heat treating process and finally the testing of the alloy to ensure the process was through.
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Scoggin Dickey....
GM Bow Tie Aluminum Blocks
Part # Part Name Price
10185075 SB Chevy Aluminum Block 350 Mains $4,689.95 More Info Add to Order
10134400 SB Chevy Aluminum Block 400 Mains $3,995.00 More Info Add to Order
24502495 SB Chevy Aluminum Block for Big Displacement $4,895.00 More Info Add to Order
12370850 BB Chevy ZL1 Aluminum Block $5,095.00 More Info Add to Order
Car: Camaro
Engine: Carbed L98
Transmission: TH350
A guy that races at the local track bought a aluminum bowtie block and swapped eveything out of his iron block motor to the new one. Everything was the same except for the block. He picked up about 1 tenth. That was just from the weight. So I figured he got little if any hp gain and was out all that money.
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
also consider that all bolt holes must be helicoiled.
stainless steel threads an't cheap.
A smallblock cast iron block is probably about 80-85 lbs heavier than an aluminum one.
I dont think the real advantage of an aluminum block is less weight. Its an added bonus.
Aluminum transfers heat better than cast iron and down there were it gets really hot, less heat=longer engine life.
i always thought the LS1 crate motor package was so overly expensive for what you got, didnt realize an aluminum block was so special. but after seeing those prices on the aluminum blocks alone, i no longer look at it as a bad price anymore lol
hey
I work in a CNC machine shop, we make Rods for Chrysler 3.3, 3.8, Ford 2.0liter Jags, we used to make iron 454 Marine heads(those were no fun, try lifting an 85pound head into a machine 2-300 times a night) and we also make some stuff for the Abrams Tanks(turret brakes mostly)
I dont understand the Aluminum price either
whenever we run aluminum, the stuff is so much easier,the machine bores, drills, cuts, etc etc all the parts much quicker. The parts are more user friendly, as burrs come off with almost no work.
Aluminum is generally easier to work with, its like a dream.
I dont get why its so much.
I understand that it costs more in the smelting and actuall casting, but cmon, it cant cost 400$$ more for a set of heads...
Q:<br>
A:<br>
Lets see, cast iron scrap price, 2 cents a pound, aluminum 18 cents a pound. :P
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
LS1 isnt a 350 tho...its a 346 IIRC plus way different.
Originally posted by No4NJunk
Well if ya want to get technical then "pre ls1" 350s aren't 350s either, they are 348s hence the 3.48 stroke.
Car: 99 Formula
Axle/Gears: 342
Originally posted by Marshall89ws6
uhhh to my knowledge all 350's have a 3.48 stroke..... and the ls-1 has a 3.62 stroke with a 3.9 bore...... so i dunno maybe im missing something but i dont see what u were getting at with that post
that's what I was thinking. Eventhough they have a 3.48 stroke, they're still 350s to my knowledge.
oops, my fault. I don't know where my head was at on that one.
2*3.14*2(radius of bore) =12.57
that *3.48 (stroke) =43.73
and that *8 (number of cylinders)=349.8 rounded to 350.
Give me a little slack. Its been one of those days.
Car: 99 Formula
Axle/Gears: 342
Originally posted by Harley83
from a performance stand point it dissapaits heat better than cast iron.
they said aluminum is better but iron is cheaper, and the performance gains, on equal type heads is not that different.
later
biker
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
so where is the extra $$392.60-----> Heli-coils!
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
