How do you install a fuel pump?
Old Nov 8, 2002 | 06:28 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
1983 camaro with 305 carbed motor...fuel pump on block....
ive got old pump out...
i kno wi have to greas the pump
when i try to put the new pump in it seems to be blocked.....i know i have to lift up something or it seems i have to....
what am i no doing right?
thanks....
gmitter
Old Nov 8, 2002 | 06:30 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
um the easiest way to explain it is put the bottom in first if I recall corectly
Old Nov 8, 2002 | 06:32 PM
Axle/Gears: 3:08
bottom in first?
forgive me if i seem stupid...i do most of my repairs my self but this has just gotten the better of me plus its 32 degrees here in nj so patience battles cold.....
can you be more specific
thanks
Old Nov 8, 2002 | 06:34 PM
SHAGME's Avatar
Car: 1988 IROC-Z
yes I know I live in wyckoff. just put the bottom towards the engine slide it down then the top should go in. its hard to explain Im srry
Old Nov 8, 2002 | 06:36 PM
SHAGME's Avatar
Car: 1988 IROC-Z
I guess tilt the top towards u then slide it in?
Old Nov 8, 2002 | 06:38 PM
Axle/Gears: 3:08
ok i think i get it....kinda roll it in bottom to top.....how much should i have to force it in or should it slide in?
this almost sounds like some other kind of lesson....lol...
Old Nov 8, 2002 | 06:40 PM
SHAGME's Avatar
Car: 1988 IROC-Z
like a virgin???? yes thats what I mean it should go in fairly easily not forcefull. its like putting in a distributer it just doesnt want to go then it slips right in. if u know what I mean
Old Nov 8, 2002 | 06:41 PM
Axle/Gears: 3:08
gotcha....i think im trying it tomorrow.....thanks again ..ill let u know if it works.......
thanks again
Old Nov 8, 2002 | 06:43 PM
SHAGME's Avatar
Car: 1988 IROC-Z
cool good luck itll be alot warmer. I need a cig
Old Nov 8, 2002 | 07:02 PM
1982chevycamaroz28's Avatar
theres a rod in there when u took the old pump out that rod slide back down. i thought i had a problem with not gettin the new pump in and then noticed this rod that i got to slide up and down, u want to slide that rod up and then put the pump back in. that rod is what pushes that handel thingy on the fuel pump.
Old Nov 8, 2002 | 08:27 PM
Axle/Gears: 3:08
hey i see we have basically the same mods to our motors......i dont have the intake you do..i have a stock one....thanks for the tips on the pump.....
Old Nov 8, 2002 | 11:00 PM
TBI305Camaro's Avatar
Man that sounds much easier than replacing the intake pump. I replaced that last winter when it was snowing out
i wanted to run a machanical pump on this motor since i went carb but no provision for it
Old Nov 9, 2002 | 05:26 PM
SHAGME's Avatar
Car: 1988 IROC-Z
did u fix it?
Old Nov 9, 2002 | 05:36 PM
Axle/Gears: 3:08
tried.......didnt realize you had to slide it up ....doing it tomorrow when i hav light......
Old Nov 9, 2002 | 05:55 PM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
I've changed mine so many times i could do it blindfolded now. The first change took me 2-3 hours fumbling around.
Tip: take a slender magnet with left hand and attach to the rod, slid it up. With right hand place the lever from the fuel pump underneath and line up. (needlenose pliers will work too, but get in the way more). Start your two bolts and finger tighten - this will allow you to better line the fuel line up, which is also a bear. Then tighten eveything up!
(assuming right handed)
I hate working in the cold as well. Don't have as much of a problem here in Georgia
Old Nov 10, 2002 | 11:07 AM
SHAGME's Avatar
Car: 1988 IROC-Z
No guess the one I just did didnt fall down like that
Old Nov 10, 2002 | 02:39 PM
Axle/Gears: 3:08
well i got it in.....it wasnt hard at all once you guys told me how to do it...lol
thanks again for all your help
Old Nov 10, 2002 | 02:58 PM
SHAGME's Avatar
Car: 1988 IROC-Z
glad u got it runnin how much did it cost u for the rebuild? and where di u get it done? thnks
Old Nov 10, 2002 | 03:02 PM
Axle/Gears: 3:08
I had the motor rebuilt when I lived in Florida....which is where that pic was taken(the skulls are no longer on the car either) the motor came out of a 1986 van.... had 345000 miles on it.....so i had a guy i know who owns a machine shop(hes the local guy that everyone reccomends) work the motor and another friend of mine owns a shop so it worked out nicely......
sorry though it wasnt done in nj so i cant help you with who to go to up here
cost of motor 100 bucks
motor work 600 bucks(knew the guy remember) (1100 retail)
intall 200 bucks(500 retail)
Old Nov 10, 2002 | 03:06 PM
Axle/Gears: 3:08
whoops...meant to post motor pic......let me try again
Old Nov 11, 2002 | 11:40 AM
SHAGME's Avatar
Car: 1988 IROC-Z
ok \cool thnks I used to live in pt st lucie then in jensen beach. I hate the cold should never have moveed back to NJ. but better $$ up here.
Old Nov 12, 2002 | 09:37 PM
Axle/Gears: 3:08
yeha i hear ya but im still going back....my car hates me for moving....lol
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
