Head gaskets blown
Old Nov 11, 2002 | 03:34 PM
StylnCamaro's Avatar
Head gaskets blown
I blew one of my head gaskets or possibly both of them but I'm sure it's just the one. Just to make sure it is a blown gasket, I'm loosing oil and antifreeze fast and also smell gas fumes in the antifreeze resevoiur, does that sound like it? Plus the car constantly smokes when running(white smoke). So what am I gonna have to spend to get one or both fixed? I have a 89 Iroc 350 and don't want to junk the car b/c I love my camaro has 80K on it and a 1600.00 tranny i just put in. So let me know what there gonna rape me for
Old Nov 11, 2002 | 03:57 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It ain't gonna be cheap.. Any way you could tackle this?? Gaskets are only $40 or so, labor is gonna put you at a minimum of $500 I would think, prolly more.
Old Nov 11, 2002 | 04:21 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Blown gasket?
Do you have coolant in the oil?. Check the oil dipstick.
Old Nov 11, 2002 | 06:24 PM
kevinc's Avatar
Car: 1982 Z28
Lack of coolant in the oil doesn't rule out a head gasket blown. If your radiator smells like exhaust you have either a head gasket blown or a cracked head.
If you pay a shop to do it, figure about $300-500 in labor costs.
Old Nov 11, 2002 | 06:42 PM
ede's Avatar
ede
why don't you leak it or do a compression test them you'd have a better handle on what your problem might be.
Old Nov 12, 2002 | 08:46 AM
what kind of heads do I have? Cast iron, aluminum? They are the reg stock heads
Old Nov 12, 2002 | 09:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are cast iron if they're original.
Do a compression test before you start, see what's really going on.
Old Nov 14, 2002 | 06:45 PM
Now the car won't even start at all since it was ran, any ideas of what it could be? Oil is good no antifreeze in it, antifreeze is good, car just won't start. Have power everything and the battery is maybe 2 mo new. Go to start and it just won't crank????Please help!
Old Nov 15, 2002 | 08:43 AM
Denis.V's Avatar
Axle/Gears: No idea
No crank???: Too many compression in one or more cylinders. Cause could be a missadjusted valve (it don't opens).
This was my problem.
Regards,
Old Nov 15, 2002 | 11:46 AM
what was the price to have it fixed? Round about figure and I take it would be a big jog to do? Meaning call a reg mechanic or call a person dealing with motors
Old Nov 15, 2002 | 12:54 PM
Denis.V's Avatar
Axle/Gears: No idea
Price?, Only the spare parts if they are needed (the rocker arm nuts). I started with the job. All the help that you needs is in this forum (valve adjustment, etc, etc.)
Old Nov 15, 2002 | 04:42 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
If solenoid clicks but engine doesn't turn (or turns slow and stops) , and you suspect head gasket failure, you have an hydraulic lock caused by water in one or more cylinders. Water is incompressible and will cause the piston to stop dead. Not good for rods. Pull plugs and see if it will turn over then. Water will come out of the cylinders that are affected.
Andy.
Old Nov 15, 2002 | 06:28 PM
well I lefdt a message for one of the local machine shops/engine detailer and he said from everything I described that the engine is froze, and can get me a used 350 installed with all my parts for 1995.00 but that is all I know, we are playing phone machine games right now
Old Nov 15, 2002 | 06:36 PM
ajm_shorty's Avatar
I wouldnt put a used engine in maybe a rebuild but you probably dont got that bad of a problem yet. you should pull the plugs and try to crank it. As for the head gasket...I would do that myself...But you want to keep your engine if it only gots 80k miles on it
Old Nov 15, 2002 | 07:21 PM
Denis.V's Avatar
Axle/Gears: No idea
No, no, no StylnCamaro:
If you ask to 10 mechanic shops, you' ll hear 10 different expensive "solutions".
This board has a most advanced tech level for your help.
it's time for start learning yourself about your fabulous engine. In the next future, you'll known all about the engine maintenance, repair and modifications.
Mech. shop will solve this problem only. The next month, you'll have other problem and then...? what...? more money?....
Old Nov 15, 2002 | 07:41 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I'm going to give you a fun warning about head gaskets and mechanic shops. All of the shops around here quoted about $1,000 to change the head gaskets. I would follow every suggestion in this thread before you have that shop drop a new engine in.
I bought my 89' GTA with what I suspected was a blown head gasket. I would've changed the gaskets myself, but when we got the heads off we found two 4" long cracks in the water jackets. Cyl, 3&5, and 4&6 to be exact. Heh, guess that rules out a blown head gasket! *the search for a new engine continues!*
Do the compression and leak down test, and do everything else these guys have suggested. *Within reason though, not everyone who posts here is trained, and/or knowledgable. Especially me!*
Old Nov 16, 2002 | 04:59 PM
N8Miller's Avatar
stylincamaro:
my suggestion........bore your block out to a 383 and get a dececnt size cam and nice set of heads. this combo dont have to be extreme, just something to make that tranny work like it should. there are lots of quaility used parts in the classifed section and on ebay. this would save you that precious money and help ya get into that mid-13 second range that your looking for ------ for abou the cost of 3000 or so dollars. i got that good mechanic, just let me know what you wanna do, when you wanna do it and will bust our asses (me and nevinkez) to save you the most money and get you the most HP.
But, for ony having 80k on the block, it would have been a good idea to keep it, but a cheap 383 stroker kit and use that. get at me.
3rd gen money
Sep 8, 2015 11:40 PM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
