do you think this will get me into high/mid 12's?
Old Nov 11, 2002 | 05:09 PM
87transam5.7tpi's Avatar
this winter I am building anew motor fo rmy car. here are the specs
355 engine
4340 forged crank
4340 forged rods
forged pistons (10:1)
- custom camshaft like traxion's
- 230º Intake Duration (Xtreme Lobe)
- 245º Exhaust Duration (Standard Hi-Lift Lobe)
- 0.544" Intake Lift (1.6's) / 0.548" Exhaust Lift (1.52's)
- 113 LSA
AFR 190cc heads
TPIS intake
SLP runners (semi-siamesed)
Ported plenum
SLP headers
mufflex 4" catback exhaust.
3000rpm stall converter
aluminum driveshaft
LCA brackets
LCA's
and 3.73 gears backing it all up.
do you think that will work w/ prom tuning to get me around 12.5 in teh 1/4? I just wanted to see what people thought before I ordered all of the parts
thanks
Old Nov 11, 2002 | 05:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you can hook, I'd give you a good shot at it. At least high 12s.
Old Nov 11, 2002 | 06:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd say yes definitely if how have the traction, or close even without.
Old Nov 11, 2002 | 09:43 PM
MdFormula350's Avatar
hard to tell, but seems like a very fast combo!!
12s would be awesome..
Old Nov 11, 2002 | 10:00 PM
Marshall89ws6's Avatar
yea if u hoook..... i have a ton of trouble hooking and my setup isnt too much different from that one
Old Nov 12, 2002 | 12:52 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Thats a big cam! are you planning on staying with the long tubes?
Trax is using a Miniram remember.
should scoot though.
Old Nov 12, 2002 | 02:54 AM
flashincamaro's Avatar
I think if you go with a miniram you got 12s easy I heard some not so good stuff from guys around here with the slp runners I know one guy even got slower with them?? how I don't know but they all went to something like the miniram , stealth or carb I know one of the guys gained about 5 car lengths by going to a miniram just cost to damn much money for me I will stay with my old camaros and there carbs LOL maybe thats just cause im getting old
Old Nov 12, 2002 | 09:13 AM
I plan on switching to miniram or something later in the summer. it'll still be the old TPI beginning of summer though.
Old Nov 12, 2002 | 09:43 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
why not go 383 since you will be buying a new crank, rods and pistons anyway. Just clearance you block an you would be good to go.
Old Nov 12, 2002 | 09:54 AM
I've read/was told that a 383 you have to run a small cam for clearance. and w/ that cam I was going ot go w/ I didn't think I could pull off the 383.
Old Nov 12, 2002 | 10:17 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Well you have to get the right cam. A small circle base cam. They should be able to grind a cam to your specs.
I have a friend running over .650 lift in a 388. You just have to tell them what you need. Call comp and tell them you need a Xe282hr cam but in a small circle base grind. They should be able to help.
I was going to go with a 355, but since I was buying new bottom end stuff, why not just go with the 383. More hp and tq.
Old Nov 12, 2002 | 10:19 AM
you da man bluegrassz, thanks. More power for me now :hail:
Old Nov 12, 2002 | 01:05 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
If you are not going to get 12's with traction then I am going to need to redo my whole engine. I am planning on running in the 12s with this combo
355
stock rods, crank
10.5:1 flattop pistons
224/236 .512 .525 112 LSA (1.6 rr)
Ported to hell TPI (for now, Mini Ram to come)
Pro Lighting 64cc heads (cleaned up) 2.02, 1.60
Custom Prom
Long tube headers
custom bent exhaust
Adj LCA's/relocation brackets, Panhard, Hopefully will get adj torque arm, SFC
Of course I will be loosing a lot of weight as well.
I have a friend running very similar and he is in the 12's with traction but that is very hard to come by. Now I do understand that with the TPI that I may only be in the low 13's but I am hoping for 12's with the right tune.
Old Nov 12, 2002 | 01:26 PM
i like the carb setup..... simple.....not less sophisticated but more hands on........ carbed motors sound better.... its cheaper.......i just think its the way to go.... esp with a 383.
mw66nova
47
Jun 1, 2006 09:13 PM
TBI92Camaro
Theoretical and Street Racing
41
Oct 12, 2004 02:44 AM
chevySS
Oct 16, 2001 07:51 PM
Biochem
Carburetors
Jul 18, 2001 03:05 PM
