Dead Speedometer
Old Nov 12, 2002 | 12:07 AM
jyoungtn's Avatar
Dead Speedometer
I just bought my first camaro and the speedometer has died on me. It is a 91 Z28 and I am looking for any help finding the problem and fixing it.
Old Nov 12, 2002 | 08:25 AM
Vader's Avatar
J,
Welcome Aboard!
The speedometers in our cars are electically driven, not mechanical. They require a working Vehicle Speed Sensor (VSS) to provide the pulsed signal to the speedometer and the vehicle's ECM for control information. The VSS on most of our cars is mounted in the tailshaft housing of the transmission.
Absence of this signal to the ECM will also set an error code after driving a short distance, and turn on the SES lamp on the dash. You can verify whether or not you have this problem by scanning the ECM for error codes. It is very easy, requiring no special tools, and takes about five minutes. If the ECM displays the error code for a failed VSS, you may have a problem with the electrical connector at the VSS, connections at the in-line buffer module for the VSS, or a failure of the sensor or driving gear itself (it is driven by a small plastic gear like the old mechanical speedometer cables). If there is no error code present, the ECM is receiving the correct signal and the speedometer is either NOT getting the signal or has malfunctioned. After determining that, you can decide whether or not to remove the speedometer for repair or replacement. Incidentally, there are electrical connections for the speedometer as well, so don't overlook those if you get that far in the diagnosis.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Bigold4x4
Sep 28, 2015 05:21 PM
