a thirdgen lawn ornament?
Old Nov 14, 2002 | 08:17 AM
sanchez's Avatar
Car: 1990 Iroc-z G92
Transmission: 5 Speed
I own a 1990 IROC With a 305 tpi and manual transmission and it goese nowhere . I will press the cluch down and turn the key and nothing the starter dosn't do anything. I can here a small click come from my drivers side kick panel and fuel pump turn on so I know it not the (Vats ).I ve replaced the battery, battery cables and less than 7 moths ago replaced the starter and ignition switch. we tried to push start the rock and the @#$* thing ran. im puzzled I need help.
Oh could i disconnect the neutral saftey switch and use a piece of wire to bypass it as a test to see if it is bad?
Old Nov 14, 2002 | 08:19 AM
ede's Avatar
ede
yeah i'd jump the safety switch, i'd guess it's bad
Old Nov 19, 2002 | 08:02 AM
sanchez's Avatar
well after lots of searching and many many days of frustration i finaly gave up.
I just went ahead and bought a push button starter switch so now the problem is gone and the switch looks great in the old cigarete lighters home.
thanks
Sanchez
Old Nov 19, 2002 | 10:17 AM
MdFormula350's Avatar
cool! glad you found a way, a push button sounds cool...
Old Nov 19, 2002 | 02:44 PM
Vader's Avatar
There are two switches on the clutch arm - one for the starter interlock and the other for the cruise control (if you have one). It almost has to be one of those two switches or the circuit, unless the car has an aftermarket alarm system.
Old Nov 19, 2002 | 03:53 PM
BikertrashDude's Avatar
thanks
Sanchez
hows that work?
do you still have to use the key?
or can anyone just get in the car and push the button?
thanks
biker
Old Nov 20, 2002 | 10:20 PM
sanchez's Avatar
I still need the key to use the button so no one can run off with my car . but it is also set up so it can only start with the key in the run possition. it has solved all of my starting problems so far I hope it stays that way.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
bryan623
Aug 10, 2015 11:33 AM
