Headers glow red!!!
From: Newark,NJ The state where racing on I 78 rules.
Headers glow red!!!
If I rev my car in neutral the center 2 header tubes glow red! Does that mean my car is running lean? Also when the car idles the fumes make your eyes tear & the stinch get all in your clothes!! There is no visible smoke & there is no cat on the car.
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Both of those symptoms (glowing headers, exhaust that burns the eyes) indicate late ignition timing. Check it with a timing light, and I would expect that you are 10 or 15 degrees late.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A lean condition and late timing are my choices also however you mention only the center 2 tubes are glowing.
To me that would mean only those cylinders are running lean which doesn't make any sense. Check the header gaskets. Check the spark plugs (very clean and white is lean). Check in intake gaskets. Maybe those cylinders are sucking in extra air from a bad intake gasket.
Running rich has a cooling effect which lowers exhaust temperatures.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Glowing headers is definatly a danger sign.
You need to correct this or sever engine damage can result.
Late ignition timing is usually the cause. But it can also be rich or
a lean condition or a combination. Since it only happens on 2 cylinders I'd check the firing order. Wouldn't be the first time.
The timing may not be advanceing when yu rev it.
Or the injectors are faulty.
Any number of ECM programing faults could cause this too.
Car: 87 IROC L98
Doh! I never even thought of a TPI system. Yes you could have a couple of bad injectors not supplying enough fuel to those cylinders.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
__________________
Not always. Rich fuel mixture tends to burn in the headers. When timing is late.
__________________
Car: '92 Rally Sport
Engine: LO3
Originally posted by Mark A Shields
I'm sorrry ba bit drunk right now, but what about a clogged cat, but yes a lean conditno will cause it too.
But you've gotta get rid of those pink elephants first... hehe. Damn, that make me want some beer right now. So raise your hands, those of you that are gonna have a hangover on Sat. at the thirdgen nats... ME, ME!!!! *Harry raises both hands* What Mark is seeing right now----> :lala: :lala: :lala: :lala:
Car: 99 Formula
Axle/Gears: 342
Originally posted by 1MEAN92RS
Hey Mark, when you sober up and can read straight re-read 86Tra/maro's post. You might find out he doesn't have a cat at all.
owww, my head hurts. If it's running rich it could also make the headers glow, what happens is the explosion in the cylinder still burns as the exhaust valve opens. In other words, it shoots flames out the exhaust ports. I had that problem with mine because I had it running too rich. Once I leaned it out a bit, no more problem.
Stephen has a good point with the injectors though, it could be going two ways. They could be clogged, or just letting too much fuel in. A good and easy way to check if they're leaking is to put a fuel pressure gauge on it, prime the system, then turn the igntion off. If pressure starts to drop automatically, you've got problems with the injectors.
Timing is also an issue of glowing headers, but it shouldn't only effect 2 primary tubes, all of the tubes would glow.
The 2 center tubes on both sides of the motor glow first & then the remaining tube starts to glow. I have the dist set at 6degrees and my chip has 15degrees at idle. At about 2000rpms the timing is at about 25deg. with light throttle input from the tps sensor.Ive tried disconnecting the various vacumn lines & plugging them but I still get the burn your eyes stinch from the exhaust. thanks again.
njdaewoo
njdaewoo
Car: '87 Camaro LT
Engine: 355 L98
i would definitely play with the timing, especially since you have all those mods done. i'm running about 18° advance, it hates anything less than 12. pull the plugs out, they should be a light tan color, yours will probably be very white and possibly melting from the heat. if they are you need to move to a colder heat range plug. i'm assuming you know to disconnect the timing connector when you set timing so this is just a reminder
what about valves
along with timing could it be possible that those 2 cylinder exhaust valves are not closing properly? Although timing not advancing and late timing will do this but how do we explain the gas fumes if it is running lean?
Yes I know about setting timing.
Question:along with timing could it be possible that those 2 cylinder exhaust valves are not closing properly?
Answer this:
Its not only the 2 center header tubes, its all 8 of them. The 4 center tubes glow red first & the outer tubes. Maybe my 30lbs SVO injectors dont like chevy engines
I have the injector constant set at 32lbs with the chip burning program. my fuel pressure is 35 @ idle & 45 @ wide open throttle. Remember the headers glow red while the car is revved in neutral at a steady1800rpm for about 45 seconds. I have no idea of what to do about the burning eyes at idle either.
Answer this:
I have the injector constant set at 32lbs with the chip burning program. my fuel pressure is 35 @ idle & 45 @ wide open throttle. Remember the headers glow red while the car is revved in neutral at a steady1800rpm for about 45 seconds. I have no idea of what to do about the burning eyes at idle either. Senior Member
Car: 91 camaro
Engine: 383
Pull out all your spark plugs and take a look at them. This will tell you a lot: if you are rich or lean, and if all your cylinders are running evenly.
dave
I think what he is trying to say is that the timing is a little late and the fuel is too lean so as the exhaust valve opens, the fuel is still burning causing the combusting gasses to heat up the two header primaries. Typically a lean condition would have this affect on the rear cylinders as they tend to be the ones to lean out first.
