Newbie needs help
Old Nov 15, 2002 | 01:37 AM
jyoungtn's Avatar
Newbie needs help
While working on my car this evening a plume of white smoke came out of the exhaust. I am not very familiar with cars and any assistance in determining and fixing problem, if any, will be greatly appreciated.
Jeff
Old Nov 15, 2002 | 02:21 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
well a few more details would help
was it when you started it....what motor do you have......what were you doing to it when you were working on it.....
white usually indicates coolant in the exhaust.....
but give some more details so we can helpyou as best we can
Old Nov 15, 2002 | 10:55 AM
jyoungtn's Avatar
I was checking the fluid levels and just doing some other basic maintenance things. After I was done I cranked her up and just let her idle until I saw the smoke. The engine is a 350. There was also some blue smoke in it as well.
Old Nov 15, 2002 | 10:57 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Like said white smoke usually means coolant being burned, blue smoke is oil being burned.
Old Nov 15, 2002 | 12:21 PM
jyoungtn's Avatar
Does anyone have any suggestions for the cause of the smoke and ways to go about fixing it?
Jeff
Old Nov 15, 2002 | 12:40 PM
gruveb's Avatar
Car: 1989 IROC-1
Any other symptoms?
Old Nov 15, 2002 | 12:47 PM
jyoungtn's Avatar
I haven't noticed any. The car doesn't seem to be leaking any fluids and it isn't overheating.
Old Nov 16, 2002 | 02:11 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
does it smoke all the time now? or was it just a single puff? you can try tasting the water/condensation that comes out of the exhaust (spit it out lol), if it tastes sweet then you're getting coolant in the engine and will most likely need to replace the head gaskets
rubblerubble
Mar 13, 2016 06:57 PM
R3500
Aug 24, 2015 09:05 AM
jeepman
Aug 17, 2001 08:13 AM
83Z28
Carburetors
Jan 5, 2001 05:15 PM
