Hard Gas Pedal
Old Nov 15, 2002 | 10:43 AM
plohound's Avatar
Hard Gas Pedal
What does a hard gas pedal mean? It is simply hard to press on it...........
Old Nov 15, 2002 | 10:46 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Check your throttle return spring... It may be caught on something.
Old Nov 15, 2002 | 10:49 AM
loudpedal's Avatar
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
try this
You need a leadfoot to press the loudpedal........
I just couldnt resist.......
Try lubing the throttle cable (or replacing...they do go bad) and check for binding or excess return spring pressure on the bellcrank end. Also check the under dash pivot points.
Old Nov 15, 2002 | 10:51 AM
plohound's Avatar
What does this mean for someone with no mechanical experience whatsoever? How much should a mechanic charge for this?
Old Nov 15, 2002 | 10:54 AM
Car: 99 Formula
Axle/Gears: 342
this is one of the easiest things believe me, do you have carb or tpi?or tbi?
either way pop the hood, if you want have someone hit the gas , car off of course, and look for a lever that moves, you should see a spring on it. that's the spring we're talkin about.
Old Nov 15, 2002 | 11:02 AM
plohound's Avatar
Ok, I actually know the lever your talking about. What do I do once i have someone press on the gas? If I need to lube the cable, what type of lube should I use? Oh, it's a carb 84z to be exact. Thanks!
Old Nov 15, 2002 | 11:39 AM
Car: 99 Formula
Axle/Gears: 342
Well, don't worry about someone pushin the gas then, pull back on the lever and look at the cable as it moves, does it not stretch out the way it should, as you pull back? You may just need a new spring, or make sure it isn't hitting anything.
Old Nov 15, 2002 | 01:48 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Ever since I converted from TPI to carb my gas pedal is annoyingly stiff also. With a dual return spring its real annoying so I only run 1 spring and its still too stiff.
Old Nov 15, 2002 | 03:59 PM
plohound's Avatar
lubed the throttle cable...feels a little better! Thanx
1992 Trans Am
May 10, 2023 07:19 PM
johanlindgren
Aug 16, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
