Whats this?
Old Nov 16, 2002 | 11:24 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Whats this?
Up under the car....the plastic part/panel that covers up something between the trans and the motor. Theres somthing leaking up under there....what will I see if I take that panel off?
What would be leaking, I think its tranny fluid...
thanks
Old Nov 16, 2002 | 11:29 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Sounds like a torque converter shield to me, I'd check the bolts to it, make sure they're not loose on the converter.
Old Nov 16, 2002 | 11:37 PM
So if I take that shield off, my torque converter is up under there?
if tranny fluid is leakin from under there, what would it be,, the torque converter? do those go bad? or start leaking?
Somthing,,
I dunno, Im going to take that shield off in the morning and see what I got goin on....
Old Nov 16, 2002 | 11:52 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Pull off the cover. You'll see the torque converter.
Probably the front seal in the tranny is leaking.
Old Nov 17, 2002 | 12:14 AM
is that hard to fix? would I have to drop the tranny for that? how much would a place charg to fix that?
Old Nov 17, 2002 | 01:28 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yeah, exactly what I was thinking. Yes, you would have to drop the tranny down to fix the front seal if it's leaking. I'd make SURE that's where it's leaking from, before you do it.
Old Nov 17, 2002 | 05:41 AM
ede's Avatar
ede
call some local garages from the yellow pages to get an idea what it'd cost you. prices and labor rate vary a lot form area to area.
Old Nov 17, 2002 | 06:02 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
if it is the converter seal leaking while you have the tranny out I would put a rear main seal in it too since its right there.
Old Nov 17, 2002 | 09:56 PM
CamaroDriver's Avatar
And what better time to upgrade to a higher stall...... say ~2500?
