DP vs 4160
Old Nov 17, 2002 | 06:13 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
DP vs 4160
Whats the advantage of running a holley double dumper, or avenger over a regular 600 cfm 4160 carb. How much power difference is ther in power, which is better, how bad will gas mileage suffer?
Old Nov 17, 2002 | 06:16 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You'll have to learn to ease into the gas a little with the DP. MPG won't be the best either, but that's what I'm goin with a 650DP, I'm done with the vacuum crap.
Old Nov 17, 2002 | 06:24 PM
TBI305Camaro's Avatar
the street avenger isnt a true double pumper. It has a dual feed line but only one pump. The avenger is almost the exact same thing as the regular holley. I wouldnt get it unless you get a nice discount on it like i did,.
Old Nov 17, 2002 | 06:31 PM
Car: 99 Formula
Axle/Gears: 342
Yup, for your setup ME Leigh, you've got great heads, and a nice cam, get the 650DP or a 750VS.
Old Nov 17, 2002 | 10:14 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Since i am running the 200 cc prolighting heads, which carb would give me the best throttle response. I would really like to get the best throttle response out of this new motor!
Old Nov 17, 2002 | 10:26 PM
Car: 99 Formula
Axle/Gears: 342
I'd get either of the ones I mentioned. I hear a DP takes a little getting used to on an auto, but I'm willing to learn.
Old Nov 18, 2002 | 07:50 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Then stick with a 750 vacuum secondary. DP's are know for bogging and can be a PITA to tune.
Frozer!!!
Jan 19, 2024 04:55 PM
pont82fbird
Carburetors
Jul 26, 2003 11:57 AM
1982Camaro383
Carburetors
May 5, 2003 08:47 AM
1982Camaro383
May 5, 2003 07:03 AM
ME Leigh
Carburetors
Nov 18, 2002 01:57 PM
