Just pre-ordered Accel Wires and Plugs!!!
Old Nov 18, 2002 | 07:13 AM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I just ordered Accel Wires and Plugs from a local speed shop. This will be the beginning of my ignition system rebuild. The guy said that these plugs and wires will work with my stock cap and rotor, and I am thinking of replacing them later down the road with accel equipment also. I have a new ICM, it will eventually die because they have been dying left and right, and I am probably going to get an Accel coil. If I am correct I will be able to achieve better spark from the accel coil, hence generating better power. This should all improve the reliability of my car as well because I am experiencing ICM failure about once every 1-2 months. The car is not hacked up, it just likes the spit out ICMs every once in a while. If I replace my coil it might help, we'll just see what happens, enough of my babbering, I GOT ACCEL!
Old Nov 18, 2002 | 07:16 AM
I forgot to ask, does the stock rotor just pop off the shaft or does it need to be screwed or pryed off, this is the LH0 V6 3.1 Engine. I had the cap off numerous times to replace the ICM, it looked as if it would pop right off. Also, do I need to replace my distributor all together for better accuracy, or would it be cheaper just to leave that in and go around it, having similar results?
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
