88 Iroc Running Problems ((Please help im on the edge of buying a mustang ha)
Old Nov 21, 2002 | 08:54 AM
MadCatX's Avatar
Hello all
I have an 88 Iroc Z-28
305 TPI
THe maf sensor is un plugged, I have checked the Coil, and its getting fire. i have a new fuel pump that is wired to turn on with the key switch, the car has had alot of work and it has 230,000 miles on it...heres the problem
Last year the problem start much like the other guys problem i was reading, the car can start run fine for 20 miles or even 50 then all the sudden Just die. i put it in neutral and rev it sometimes it kicks back on and sometimes it dies. this problem has been never ending it seems. The First time we checked it, the MAF sensor was showing a problem on the computer, we un-plugged it. The MAF sensor was new. It fixxed the problem, but now its doing it again. Crank it up it runs sometimes fine, or you crank it up and it dies. I know running it without the MAF is bad, but it works and frankly i cant see drop 340 on a sensor. So any IDeas or anything would be appreciated. i have a new fuel filter im going to put in it, to see if that helps, but its the inline fuilter. is there another i should change
Old Nov 21, 2002 | 10:57 AM
TBI305Camaro's Avatar
I dont know much about TPI engines but heres a bump to the top
ttt
Old Nov 21, 2002 | 11:40 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
runs long enough to get good and hot then dies? can you start it up again after it dies? sounds like a failing ignition, check all your ignition components, especially that lil ignition module that likes to take a dump on everyone. Do you still have the coil in cap HEI? make sure that the coil mount is secure and it isnt flopping around. I would start with the basics and trouble shoot it as any other ignition problem.
how hot is the car getting before it shuts off? do you smell a heavy fuel smell, like its extremely rich? Whats it idle like? Have you checked/cleaned the IAC recently?
Old Nov 21, 2002 | 11:49 AM
87transam5.7tpi's Avatar
ya if its running rich it'll act up like that. my injectors just went out. so if I idle or get on it hard it sometimes will die from oall the excess fuel. maybe try running some injector cleaner through it. if they are extremely dirty that could make them not fully close and make you run rich too.
Old Nov 21, 2002 | 12:03 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
if it is truly grody in there...go to a mercury marine dealer or marine engine dealer and get a can of Mercury PowerTune it's marine quality cleaner for fuel injected motors, great stuff, but its about twice as much as regular cleaner you get at the auto parts store
Old Nov 21, 2002 | 02:06 PM
MadCatX's Avatar
Normal runnin temp about 180
It is running rich but im told its because of the MAF being unplugged
Whats it idle like?
Not to bad it idles normal, now lately its been rough idling right before it shuts down
not to sure what that is
Old Nov 21, 2002 | 02:13 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
idling rough like its missing? or like its stumbling/surging looking for an idle?
IAC=IDle Air Control, it controls the idle speed..it is usually plugged into the throttle body on the passenger side, its a 4 prong weatherpak connecter IIRC...pull it if it looks all blackened or corroded, clean or replace it, then reset the ecm again. it still shouldnt keep the car from running, just make it idle really bad
Old Nov 22, 2002 | 10:55 AM
MadCatX's Avatar
Well, the Darn thing ran fine today,from my friends to home and from home to work...i dunno about that damn car, it wont matter soon. I am switching to a carb.
Old Nov 23, 2002 | 02:26 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
My money's on the vats...if theivery isn't a problem it might be time for a resistor...
Old Nov 23, 2002 | 02:28 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Oops I misread - I meant the injectors Good luck.
Frozer!!!
Jan 19, 2024 04:55 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
