Overheating on the highway?
Old Nov 26, 2002 | 07:10 PM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
Ok, I just got the car and seem to be finding a new problem everday, but heres my new headache...
when it's at idle it stays cool, about 180 or so.
when I drive on the highway at a steady speed like 70 or so the temp gauge slowly climbs,
the highest I let it go was 240 and it spit out a little water, it will do it everytime ,
what do you think would cause this?
just so you know....
the fan runs all the time, I just put a new thermostat in, the lower radiator hose isn't collapsing, and its a new radiator
the base timing is 12 degrees, advance (? whatever the computer is doing) , it bogs at WOT at higher rpms 4500 just before shifting out, and it sounds like spark knock at WOT...
Old Nov 26, 2002 | 07:15 PM
rezinn's Avatar
Do you have an air dam?(a flap of plastic protruding downward from below your radiator) Are both fans coming on when it gets this hot?
Old Nov 26, 2002 | 07:36 PM
can you post a pic of the air dam?
on the car or off...
And where can I get one?
Old Nov 26, 2002 | 07:54 PM
biff85ta's Avatar
Car: 04 Vette
I don`t have a pic but it should be directly under the radiator about 3ft wide by 18inches tall if it is still intact it may be folding up at speed (mine did) I fixed mine by drilling 3 sets of two holes across the airdam then running small guage steel wire between the front airdam and the metal bumper reinforcement.
Old Nov 26, 2002 | 08:02 PM
jimmy_mac's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1873395260
Old Nov 26, 2002 | 08:16 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
you can see mine hangin down in this pic, towards the front end.
Old Nov 26, 2002 | 09:40 PM
thanks, it's definitely not there anymore
:hail: :lala:
Old Nov 27, 2002 | 10:07 AM
Vader's Avatar
You need one of these:
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
