head and cam recomendations please
Old Nov 27, 2002 | 10:31 PM
fattie92's Avatar
sup guys? havent been on the boards lately due to school. since i found time to get on the computer, ill ask a question thats been buggin me for the past few weeks.... which heads and cam should i get?? iv got a 357ci with a 3 angle valve job stock heads(dont know the casting number), and a near stock cam..forged pistons, balanced crank, performer intake, headman shortie headers, hooker cat back, rebuilt qjet....8.5 compression. what can i go with that will keep me within emissions, but give me good power? vortech, trick flow, or them pro lightning heads that i keep hearing about?..then what cam will match it good?... lets not forget that i will be putting nitrous on my car as well,...and maybe a blower (eventualy).. im a newbie to heads and cams, so i dont know too much about them... so what does every one recomend??... oh forgot to add... money is tight!
Old Nov 27, 2002 | 10:53 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Looks like you want a 180 cc head.
I just received my Pro Lightnings, $870 assembled aluminum shipped.
they were on sale though.
I'd replace the cam at the same time,even if you have to wait a little longer. Great oppurtunity to do so.
Old Nov 27, 2002 | 11:22 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Need more info on your motor and car to properly select a good cam for you.
Rear gear, trans, stall converter etc.
I'd check the casting # on the heads you have now
before making a decision on new ones. Is your motor a "flat top motor" or dished pistoned? The heads you have now may not be as bad as you think.
Here's cam that "works" in just about anything.
Crane HMV278 or Powermax H 278- 2
Specs are 222/234*@.050" .467"/.494" 114LSA.
This cam is about the limit for a stock stall converter.
It also makes an exellent Street Blower/nitrous cam when yu get that blower. This ones a winner.
See it at www.cranecams.com
Old Nov 27, 2002 | 11:23 PM
fattie92's Avatar
y do i want 180cc?? like i siad, i dont know jack about heads or cams. the pro lightnings have the EGR crap and all that on them? web site?
iv got a 2000ish stall converter on there... the guy siad it comes stock in police cars around here. the tranny is a built 700r4, shiftkit...the works, almost breaks my damn neck shifting into 2nd... rear gears are going to be 3.73 and a posi before spring
Old Nov 27, 2002 | 11:28 PM
Car: 99 Formula
Axle/Gears: 342
I was just sayin, that with a near stock cam, you don't want to be gettin 200cc heads like me, then again if you change cams, then that's a different story.
oh yeah, www.proshaver.com
www.procylinders.com I think has the specs on the head flow
Old Nov 27, 2002 | 11:29 PM
fattie92's Avatar
the cam is deffinatly going out the window!! i need more power, my friends integra is gonna be hitting 12's this summer, and maybe a 11 if hes lucky!! i need some good cheap go faster parts!
Old Nov 27, 2002 | 11:32 PM
fattie92's Avatar
ah forgot to add that i wanted to raise my compression up to atleast 9.0 also forgot that my pistons are dished
Old Nov 27, 2002 | 11:39 PM
F-BIRD'88's Avatar
Bolt on a B&M 144 or weiand 144 blower with the crane hmv 278
cam as above with a 750cfm carb on your motor as is
and you WILLl go 12's. You can port your stock heads and even got some more.
Get a good fuel system too.
This is a proven 12 sec combination. About 8psi of boost.
Needs 92 to 94 octane gas.
Old Nov 27, 2002 | 11:54 PM
fattie92's Avatar
lol... if i had the cash then sure!! more than likely the blower wont happen for me... but then again, who really knows?!? hard to say what will happen by then... but the nitrous is a for sure thing...a 175 shot, on that cam, prolightning heads, 3.73's posi and slicks, and the rest of my setup..... think ill hit 12's?
Old Nov 28, 2002 | 04:22 AM
F-BIRD'88's Avatar
yes
Old Nov 28, 2002 | 09:23 AM
fattie92's Avatar
i was looking at that cam you suggested...i thought it siad it was for a 396 and up engine?? but as long as this will all pass emissions, im game!
Old Nov 28, 2002 | 01:00 PM
daverr's Avatar
combo
well i would recommend raise your compression to 10-1 plus.with 9-1 cam selection would not be far from stock specs.
dave
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
