Flow numbers on L98 corvette heads?
Old Nov 28, 2002 | 04:01 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I was trying to find out what they were so I could plug them into desktop dyno. Thinking about some AFR 190,195,or something else. I'm not sure yet. That'll be the next big thing for my car. Then I'll just save for the cage and fire jacket.
Old Nov 28, 2002 | 05:14 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Ther're just under 200cfm@28"
Old Nov 28, 2002 | 07:44 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
here you go
intake
lift cfm
.050 29
.100 56
.200 120
.300 160
.400 186
.500 196
.600 199
exhaust
lift cfm
.050 27
.100 52
.200 104
.300 133
.400 150
.500 170
.600 175
Old Nov 28, 2002 | 08:46 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd check the Pro Lightnings, if you can swing the price, cheaper than AFR though, info here, www.procylinders.com
Old Nov 29, 2002 | 02:49 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
WOW!
I didn't think they were that good. Thanks guys.
I tried your link but it didn't work.
Old Nov 30, 2002 | 01:51 AM
FrozenFirebird's Avatar
Here are a few of the more common heads, and how they flow....
http://purplesagetradingpost.com/sum...fo/heads1.html
Old Nov 30, 2002 | 08:45 AM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
Also check out www.chevyhiperformance.com They have flowbench data on just about every head available. They also compare aluminum to cast iron. Hope this helps. This is where I got all my cylinder head info for my desktop dyno.:rockon:
Old Dec 1, 2002 | 11:55 AM
F-BIRD'88's Avatar
Here's and interesting page about some home ported
iron L-98 heads
Before and after flow test figures too.
http://www.fl-thirdgen.org/head_porting.htm
Old Dec 2, 2002 | 11:41 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
What? No votes for the TFS heads? If you look at their flow per $ ratio, they are quite good as well........
lt500r55
Sep 1, 2021 01:30 PM
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
