Need some verification/advice on cam
Old Dec 7, 2002 | 01:48 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have a 1990 305 LO3 TBI stock.
I am converting to TPI and since I am at it I was thinking of putting in a LT1 cam.
From what I have read it will work because I have a roller lifters correct?
Will I have to make any other changes or need any other parts?
I do plan on putting on headers/free flowing exhaust when I have the $. But since I will be working on the engine, while I have it apart I thougt it would be a good time to bump up the cam a bit.
Thoughts?
Old Dec 7, 2002 | 02:22 PM
Odyssey's Avatar
You wont need anything special to swap that cam in. The ONLY thing you're gonna have to do is shorten the little dowel pin that comes out of the nose of the cam. The LT1 cam's pin should be longer then normal so it needs to be shortened. Try to tap it in with a small hammer.
I'd go with a small aftermarket cam though. Maybe even an LT4 cam.
And yes you do have hydraulic roller lifters.
Old Dec 7, 2002 | 05:27 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Go to http://www.competitionproducts.com/page51.html
There is a GM small block hyd roller cam there for
$49 pn 264 HP.
A real good cam for a mild 305 tpi.
A good deal
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
