where to get 400 block?
Old Dec 8, 2002 | 09:25 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Where are some good places that I can get a fully prepped 400 block from? I'm looking to spend around 800-1000 on a block. thanks. Oh and this deal with the "high nickel" blocks. Does that really make it any stronger or better?
Old Dec 8, 2002 | 09:34 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ebaymotors.com
Old Dec 8, 2002 | 09:35 AM
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874102200
Old Dec 8, 2002 | 10:53 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
How can someone sell a fresh machined block bored .030" over and not include the pistons?
When you bore out a block, the pistons are used to measure the final clearances. The cylinder wall finish is also done depending on what rings you use. Cast rings require a different finish than chrome-moly rings.
Old Dec 8, 2002 | 11:05 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
ask seller a question!
http://contact.ebay.com/ebaymotors/a...102200&frm=284
Old Dec 8, 2002 | 12:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Go to the junkyard and get a blcok, and take it to the machine shop yourself and get the work done. It's kind of pointlessly stupid to eliminate all the 400 blocks on the planet that don't have fresh machine work (which is probably 98% or so of the total population of them) from your consideration.
Old Dec 8, 2002 | 07:11 PM
1986redbird's Avatar
Pave Tim, you have a P.M.
Old Dec 8, 2002 | 08:55 PM
Engine: ls1, LB9
old chevy vans are a good source of good and many times untouched 400s! I have gotten many 350s from them were the head gasket blew and every thing else is good. one had a cracked head and busted rings still minor stuff.
Old Dec 8, 2002 | 09:02 PM
TBI305Camaro's Avatar
I wish my 305 would have held up longer...I would have went and found a 400 and built it but I ended up with a brand new GM 350. Oh well its all good you can still make plenty of power with 350ci.
Old Dec 8, 2002 | 09:41 PM
Engine: ls1, LB9
350s are good too
Old Dec 8, 2002 | 10:06 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I just had this discussion with my machinist. I thought I'd have to get the pistons before he could bore it but it turns out that these days most all the pistons are engineered with very tight tolerances. The off the shelf pistons .030 over are already clearanced to a .030 bore. In other words 15 or 20 years ago if you bought oversized pistons the machinist would need to have those when he bored it to make sure the tolerances were in spec. Some machine shop still practice this and tell you that they need the pistons before they can do the work.
Old Dec 10, 2002 | 03:55 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
1986redbird what is a P.M.?
Old Dec 10, 2002 | 06:15 AM
personal message
either that or email him
Old Dec 10, 2002 | 11:14 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
If you have a shop in mind to do your work, check with them. Preferably one that is into race engines for stock cars. Here in the Midwest, the shops keep some engines on hand and you can get one from them without having to run one down yourself. Some shops have blocks with rotating assemblies on hand for sale. Or you can spec out what you want and they will get it ready. The shop I use had several 400's in the racks ready for rebuild.
Hotrodboba400
Dec 10, 2019 07:07 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
anesthes
Sep 18, 2015 12:34 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
84 TA NV
Sep 6, 2015 08:02 PM
