best way to remove old gasket material from engine deck
Old Dec 9, 2002 | 10:01 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
is it a good idea to use a air powered die grinder?
or is that too risky?
it looks like its going to be tough to get everything off with a gasket scraper
input, comments, suggestions?
thanx
Old Dec 9, 2002 | 10:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I've always used a gasket scraper and a vacuum.
Old Dec 9, 2002 | 11:00 AM
ede's Avatar
ede
i have a air powered scraper to get off the big pieces then use a die grinder with a wire cup brush in it, works great.
Old Dec 9, 2002 | 11:01 AM
Old Dec 9, 2002 | 12:31 PM
Vader's Avatar
I'll second the die grinder and wire cup. I don't have the luxury of having an air-powered scraper, so I use a hand scraper for the bulk of the material. The die grinder/wire cup polishes all the residue and rust formation and leaves a perfect gasket sealing surface. Since it also scatters material and wire ends all over the place, you NEED to use safety glasses or goggles, and should cover anything that might be damaged by flying particles (like your paint).
Old Dec 9, 2002 | 12:45 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Forgot. I also have used a rust stripping wheel. Works excellent even on aluminum.
Old Dec 9, 2002 | 03:35 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
razorblade. the safest thing in my eyes. i dont liek the idea of grinders and thing that take metal off. to much of a possibility of the gasket not makin a good seal.
Old Dec 9, 2002 | 03:52 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm about to do the same thing. Should I use a brass brush in the die grinder, or will steel do?
Old Dec 9, 2002 | 04:47 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I don't have the luxury of air tools so I use a wire cup brush in an electric drill after I scrape off the big junk with a scraper...works great.
Old Dec 9, 2002 | 06:16 PM
gruveb's Avatar
Car: 1989 IROC-1
I always use this strange lubricant to get jobs like that done..........a butt load of elbow grease!
Old Dec 9, 2002 | 06:33 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Use a razor blade to remove the old stuck gaskets.
Use a bunch of 3M scothbrite abrasive pads with a electric drill
to get the last little bits.
Do not install the heads till you get it spotless.
A rotary wire brush will just get a bunch of metal in the motor.
All the metal bits will destroy your rings in short order.
Try some permetex spray gasket remover.
Old Dec 9, 2002 | 06:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm still waiting for that spray gasket remover to actually work for me... maybe I got a bad can or something. When I had to do the heads for my friend's 2.8-for-2.8 swap, we just used scrapers... blew the top of the motor off with compressed air to get all the junk out of the water jackets and piston holes.
Old Dec 9, 2002 | 11:30 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
F-BIRD'88...are you talking about plain-ole scotch brite pads? Or do they make something that mounts to a drill?
TomP...for nasty, baked on gaskets (such as the runner gaskets on a 15 year old TPI engine) I used spray on paint remover. I got this wicked stuff from Sears Hardware. It was in a really tall spray can...it worked VERY well.
Golfvette
Aug 24, 2015 06:35 PM
NinjaNife
Aug 23, 2015 11:49 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
