CAM sizes.........too big too small?
Old Dec 11, 2002 | 07:19 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Does anyone know about what size duration on a cam you can have before it starts that famous lope? I know with a TBI you can't have too high of a duration, but I am curious about cam size with a carb.
Old Dec 11, 2002 | 08:05 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Look at some of the Crane Compupro cams, they are supposed to be pretty good.
Old Dec 11, 2002 | 09:16 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
My comp cam xtreme energy 270HR cam .495/.503 lift 218/224 dur. has a decent lope to it. It doesn't sound like anything radical but its a very noticeable rough idle. I don't have headers yet so i don't know how much this accents the lope.
I would suggest reposting this in tbi because people there might now how much intake duration you can get by with a stock chip. For a maf tpi i can get by with this cam but your upgraded L03 is probably already in need of a custom burnt chip.
A good cheap upgrade cam for an L03 might be a 350 tpi cam and 1.6 roller rockers, or a GM Hot cam. Regardless of the your cam choice i would suggest replacing your heads or at least do some basic port work to your heads to get the most out of a cam. Also new valve springs are a must and check your lifters when there out.
Edit: Oh ya whats your block? Roller or flat tappet? and whats the cam thats in it now?
Old Dec 11, 2002 | 11:53 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Comp xe268 has a lope in my sbc 355, but the engine doesn't shake, has good brakes. In my Pontiac 400, you can bearly tell it's in there till you drive it.
Old Dec 12, 2002 | 11:06 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
if you want a comp xe268 i'll sell you mine for $30, only has 300 miles on it, i bought it, put it in, and hate it, it's too small, so now i'm getting a comp xe284 or 292...
junkcltr
Aug 2, 2019 11:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
lt1z350
Aug 28, 2015 05:57 AM
