Removing crank sprocket
Old Dec 15, 2002 | 02:05 AM
Acidtalons's Avatar
Anyone know a good way to remove a crank sprocket while the crank is in the block?
Unfortunatly I was shipped the wrong timing chain set and this cam sprocket to match is not for a roller block and does not fit so now we have to switch to the correct set.
Old Dec 15, 2002 | 02:38 AM
radiateu2's Avatar
crank sprocket
get a cheap gear puller any auto parts store should have one to rent or buy. If I remember correctly mine just slid right off once the balancer was off.
Old Dec 15, 2002 | 06:44 AM
ede's Avatar
ede
yep, use a gear puller, they aren't pressed on very tight, usually they'll about fall off.
Old Sep 8, 2005 | 07:44 AM
llvll4l2c91350's Avatar
my new timing chain set should get here today finally. i have a gear puller to remove the crank sprocket. however doing a search i didnt find anything on installing it. what special tool do i need to install it? or will it just slide on easily? thanks.
Old Sep 8, 2005 | 10:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The crank sprocket is pressed on in pretty much the same way as the dampener is. A crank sprocket installation tool is a bushing that's used with a harmonic dampener installer.
Old Sep 8, 2005 | 12:36 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I use a metal coat hanger and hang it in front of the torpedo heater for a couple of minutes. Slides right on easily.
Old Sep 8, 2005 | 12:40 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I threw mine in the oven for a litle while, slid it on and gave it a couple love taps with a rubber mallet to make sure it was all the way on there.
Old Sep 8, 2005 | 02:10 PM
put it on the shaft and with a big enuff socket to fit around the crack snout, gave it a few taps. went right in. thanks.
anesthes
Mar 10, 2016 10:35 PM
angel2794
Sep 8, 2015 06:22 PM
mddaniel
Sep 8, 2015 05:16 PM
Night rider327
Sep 2, 2015 04:17 AM
3rdgenparts
Aug 8, 2015 07:09 PM
