More timing or more compression?
Old Dec 17, 2002 | 03:31 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I have a 350 with trick flow heads. I am gonna do a 383 and was wondering if it would be beneficial for me to go up to about 11 compression. It is fuel injected. would a jump from 10:1 to 11:1 make a big difference>
Old Dec 17, 2002 | 07:15 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The biggest difference will be the price of the race gas you'll need.
Build for a finished compression ratio of about 10:5 for alumium heads and 92/93 octane.
Old Dec 17, 2002 | 09:45 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You can run more than 11:1 on pump gas with the right cam.
What cam are you running?
Old Dec 17, 2002 | 11:18 PM
holmes677's Avatar
I figure with aluminum heads as well as the fact that it will be fuel injected will allow him to run 11:1 compression on 92/93 octane safely.
86IROC112
Aug 21, 2015 07:20 PM
Dialed_In
Aug 20, 2015 01:45 PM
NWAsonoma
Aug 18, 2015 05:45 PM
355tpipickup
Aug 13, 2015 07:35 AM
