Cam Question
Old Dec 19, 2002 | 06:07 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Cam Question
Hi All,
I have a 1989, Firebird, 305, TBI, Vin Code E, Auto Trans, Calif. Emissions.
I just put in a new stock crate motor from Jasper. I have superchip, hi flow TBI, Shift Kit, MSD Ignit.
I have 1.6 ratio Gold Crane Roller Rockers. What I need is a beffer cam that will pass Calif Smog. Any Suggestions will be greatly apprecitaed. I think I am limited due to my 1,6 rockers, but I dont know.
Brad
Old Dec 19, 2002 | 06:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
With those rockers, your lift will be increased. It's easy to run into valve spring problems.
Is your motor a roller cam motor? It was, stock; is that what you have now? Also, what heads are on it? Casting # would be best.
Old Dec 19, 2002 | 07:29 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
My motor is roller cam, I just have stock heads I have no idea what the casting number is, the car is not with me now, will be picking it up after xmas, my job relocated me so I cant give you the casting # now, sorry, what would the casting number tell you??
Also have had no valve spring problems yet, I have about 20K on the gold roller rockers.
Old Dec 19, 2002 | 07:36 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the problem is if you increase the cam, your going to have valve spring problems. using 1.5 ratio rockers would solve most of the problems. the stock heads won't handle much lift, but will handle a bit more duration.
Old Dec 19, 2002 | 07:46 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
But going from the 1.6 back to 1.5 with a bigger cam with just reduce the amount of lift defeating the purpose of a bigger cam, other than more duration with a better cam.
Old Dec 19, 2002 | 08:37 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
A bigger cam also increases duration. Increasing the lift with stock heads will yield about increase in power.
Old Dec 20, 2002 | 01:02 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Going with more duration over lift will normally give "better" results. I say "better" because you can 'over-cam' an engine.
Using a cam with the same lift and more duration is one of the benefits of a roller cam. The valves snap open faster, therefore giving the cylinder more time to fill under max lift.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
