No crank, silinoid clicking
Old Dec 24, 2002 | 10:58 PM
BPA's Avatar
BPA
siliniod is clicking but the starter is not ingaging, ill come back 15 minutes later and strarts right up? bad siliniod or could it be something else, i replaced the starter about three months ago.. could it be vats ? i thought if it clicks i was was good to go power wise, i just dont want to beleve i need a nother starter.. what do u guys think?
Old Dec 24, 2002 | 11:09 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
is it cold when it does it?
Old Dec 24, 2002 | 11:43 PM
82camaro's Avatar
Car: 82 camaro SC
Could be the solenoid sticking. Verify all the connections are tight and remove and clean the terminal connections at the battery. Corroded terminal can do that.
Old Dec 25, 2002 | 12:24 AM
BPA's Avatar
BPA
cold or hot, happened after sitting all day after work, waited an hour and came back and started right up. I tryed hitting the starter, but no dice.a nother time i drove it stoped after drivign to get gas and it didnt start up for a 20 minutes. slick click from teh siliniod but no ingagement. Im at a loss. BAtery is new with no corosian at the termainals. I checked all conections and they are all tight nothing loose......
Old Dec 25, 2002 | 11:57 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
maybe the power wire to the started has a bad connection... other that that replace the solenoid... sounds like its bad to me
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
Linson
Oct 1, 2015 09:50 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
