Roller Rocker help..!!!
Old Dec 28, 2002 | 02:20 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm about to do some ordering, but I'm undecided on which rockers to get.
At first I was going to get the Comp Magnum Steel roller tip rockers for $140 or so, but isn't the roller tip not that great? CCA 1416-16
There is also some Crane roller rockers for $190 CRN 11746-16
Summit also has an aluminum brand made out of T6 aluminum, supposedly stronger... But I know most on here say aluminum for the street is a no no, does that pertain to these as well for $160 SUM G6906
Which should I get, I'm tryin to not spend a fortune, but if the Crane's are that much better for another $50, then I guess I'll get them.
Thanks.
Old Dec 28, 2002 | 02:23 PM
rezinn's Avatar
Anything you get from crane will be better than the stock pieces, even the roller tipped ones are way better. The construction is like that of an actual precision movable part, rather than a formed piece of sheet metal. I was on a budget and bought the roller tipped ones. If you want to spend the exta 50 bucks on full rollers, go ahead. I wouldn't go with the aluminum ones. CrMo>>>>>>aluminum.
Old Dec 28, 2002 | 02:27 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive got a set of comp magnum RT's. There not bad I took them off my old 355 and they dident have any wear about 10K miles so...
Ive seen the aluminum rocker not fair well there should even be a thread a few weeks back with some pictures by V8astrocaptin.
Old Dec 28, 2002 | 02:34 PM
Car: 99 Formula
Axle/Gears: 342
OK, so the summit ones are out, would the extra $50 for full roller ones over just tips be worth it?
I see in Summit, that the Comp RTs might have a rail on them, meaning they're SA right? then I wouldn't need new pushrds, thus saving me $80.
I've heard Crane sells some 1.7s, anyone know how much these are?
Old Dec 28, 2002 | 06:07 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I wouldn't bother with anything aluminum. I had a set of Crane Gold roller rockers and they lunched themselves in less that 10k miles.
I now have a set of the Comp rollers that everyone here seem to have good luck with. I haven't run them yet but I don't want to go thru the same **** I did with the Cranes....unless you like finding metal shavings in your engine.
Comp makes 1.7 ratio rockers for the SBC. They only offer them in the stainles steel and they run close to $400.
http://compcams.com/catalog/287.html
Old Dec 28, 2002 | 06:40 PM
ede's Avatar
ede
i'd buy the steel full roller trunion type from comp pn 1318 for 1.6, in SA
Old Dec 28, 2002 | 07:05 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The Crane Blazer roller rockers work very well.
If you want a alumium roller rocker that will outlive you,
get a set of Scorpion Rockers. If you want to get high ratio rockers just be sure that your valve springs can handle the higher lift. You can't use self aligning rockers with pushrod guide plates. It's one or the other. not both.
Here's some beauti rockers you can checkout
http://www.enginekits.com/specials/specials1.html
Here are the Crane Blue Racer "Blazer" roller rocker
http://www.blueracer.cranecams.com/chevysb.htm
PN# WG-3060 3/8 stud 1.5:1
Not the same beast as the Crane Energizer rocker.
Old Dec 28, 2002 | 07:14 PM
F-BIRD'88's Avatar
Old Dec 28, 2002 | 08:35 PM
Marc 85Z28's Avatar
Re: Roller Rocker help..!!!
Hey! I've got a set of those unused (new) and for sale if you're interested. I opened everything, and trial fitted 2 rockers and found the pushrods hit the heads, so I never installed them. I decided to go with the Pro Mags instead. My loss, your gain - $150.
Old Dec 28, 2002 | 08:51 PM
DABE's Avatar
i have come comp cams 1.52 roller tiped rockers...i will sell them to ya for CHEAP!!....
right now on my camaro i have 1.65/1.5 comp cam full rollers...140 bucks for 8!...i also have a grand in my valvetrain...but thats another story...
let me know if u are interested...
Old Dec 28, 2002 | 08:52 PM
Car: 99 Formula
Axle/Gears: 342
Re: Re: Roller Rocker help..!!!
wow, good price, only thing is I have a summit gift card I'm using for all this, maybe we could work something out with that, I'll PM you now about it.
Old Dec 28, 2002 | 08:53 PM
DABE's Avatar
heres a pic of my setup now...
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
