Heads on a 400?
Old Jan 2, 2003 | 03:48 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Heads on a 400?
Just wondering if any set of heads can be bolted up to a 400 block. Like Aluminum L98 heads or AFR 190/195s. I know about steam holes and such but to coolant passages and stuff all line up the same??
Old Jan 2, 2003 | 03:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
Old Jan 2, 2003 | 06:16 PM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Merci
Old Jan 3, 2003 | 05:35 PM
ohyeahjay's Avatar
if your running it on the street it is highly recommended to have steam holes drilled in them
Old Jan 3, 2003 | 09:12 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
my machine shop told me i had to have steam holes drilled in them for them to work on a 400, i could be wrong though
Old Jan 3, 2003 | 09:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're not wrong. Drill the steam holes. It's 6 holes per head with a 3/16" drill bit using a 400 head gasket as a template. About 5 minutes work, taking it easy and counting beer breaks. Doesn't get much simpler than that.
Old Jan 4, 2003 | 12:28 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Yes, the latest Chevy High Performance mag has a how-to article on it.
Old Jan 4, 2003 | 12:40 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The only small block head that you can't use on a 400 block are
the 350 LT-1 and LT-4 reverse cooling genII type of head.
There is no point in trying this as the Vortec and Fastburn head are fashioned after these and flow way better and are cheaper.
The LT-1 type EFI intake manifold can be adapted to the earlier
GENI head thou.
C409
Sep 23, 2015 04:30 PM
camaro71633
Sep 1, 2015 10:24 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
lakeffect2
Aug 23, 2015 08:44 AM
