461 small block
Old Jan 2, 2003 | 04:26 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
461 small block
i saw a 4.25" SBC crank on the holley website. i was just wondering how much machining and work on the block it would take to make it work? what else would you need to do? do they make pistons you can use with 6.125" rods you need to use with a stroke like that? just thinking...
Old Jan 2, 2003 | 05:59 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You would have to have an aftermarket block to make it work.
Old Jan 2, 2003 | 08:49 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You would need an aftermarket tall-deck small block.
Old Jan 3, 2003 | 06:01 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
GM ROCKET BLOCK!!!!!!!!:hail: :lala:
Old Jan 3, 2003 | 06:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Definitly the rocket block. Once your done, there's not much else left to consider calling it a SBC.
Don't forget that you're trying to feed a SBC that's the size of a BBC with tiny SBC heads. An engine like that would have to have a supercharger just to be able to force enough air through the heads.
Old Jan 5, 2003 | 07:47 AM
Engine: V8
heh, bout time i was right...
Old Jan 5, 2003 | 09:26 AM
Terry Kennedy's Avatar
Car: 88 IROC
Transmission: pg
Axle/Gears: 9" w/3.89
Motown block would be a better choice for the money. That's what I plan on buying
Old Jan 5, 2003 | 09:57 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Motown blocks are excellent peices, but would not work for this. It has to be a tall deck block with raised cam location. The Motown is standered heigth.
Old Jan 5, 2003 | 11:03 AM
AlkyIROC's Avatar
Car: 87 IROC L98
The Motown block can be bored out to 4.200". Using a standard 3.75" 400 crank only gets 415 CID. If it was possible to stick in a 4" stroke crank then it only jumps to 443 CID.
It's not possible to get that much displacement from a standard height block. You need to buy exotic parts or just use a BBC.
Old Jan 5, 2003 | 02:09 PM
Car: 88 IROC
Transmission: pg
The motown will execpt a 4 in. stroke crank and also the 4.20 bore and still have room left to be safe. Like you said that makes 443 but that is still an sweet small block. Bill Mitchel is now offering a 443 crate motor for around $15,000.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
64goatman
Sep 9, 2015 01:09 PM
84 TA NV
Sep 6, 2015 08:02 PM
