Stumped!
Old Jan 3, 2003 | 05:18 PM
BurnoutBoogie's Avatar
Stumped!
Well, this post goes hand in hand kinda with my other post about my vaccum leak. After I reinstalled my distrib, the vaccum leak started and so did this quirky little starting problem. When I crank the engine with my foot off of the gas, if will turn over for about 2 turns, then the stall for half a second, turn again for about 1 turn, stall once more, then the engine fires right after that. BUT, the funny thing is, if I hold the accelerator to the floor, the damn things doesn't stall, 2 cranks and she fires right up! This has me confused and , haven't encountered anything like this at all. Right now, I haven't even a GUESS of what is causing this. Any suggestions would be helpfull.
Burnout
Old Jan 3, 2003 | 05:48 PM
RJR99SS's Avatar
are you positive you hooked the plug wires back to the distributor in the right order?
Old Jan 3, 2003 | 06:20 PM
Positive. I didn't even take the wires off of the cap, just the cap off of the base, and the base out of the block. 'Tink I woulda noticed a screwed up firing order!:sillylol:
Burnout
Old Jan 3, 2003 | 06:26 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Sounds more like a carb getting fuel problem to me. The first couple times is just getting it primed. Try pumping it some, then crank it over. I know when the weather got cold, I have to pump the h*ll outta my edelbrock 750. Here is mine when it is cold , pump about 50 times then crank it fires then quites. Pump about 30 times then crank, it runs for about 3 seconds, then last pump about 20 times and give it about 1/4 throttle and it fires up. But once the car warms up, it runs like you wouldn't believe.
Old Jan 3, 2003 | 06:34 PM
50,30,20 pumps?:sillylol: I figure youd be outa gas by then!! I thought that also, but that all it takes to get started is 2 pumps. Even then, lack of fuel would make then engine turn over and over until there was enough present for it to start, and thats just my problem, it doesn't want to turn over consistenly. Maybe I should check my starter lead again, it IS close to my headers....
Burnout
Old Jan 3, 2003 | 07:02 PM
385LT1's Avatar
If you are referring to starting the engine 1st thing in the morning or first time of the day, or after the car has been sitting for awhile.
You will need to tap the gas pedal to set the choke.....
this could be why it starts when you push the gas pedal.
Old Jan 3, 2003 | 07:04 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
How about your sylenoid??? I think that is how you spell that.
Old Jan 3, 2003 | 07:07 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
I am talking about after mine has set for like 24 hours. I can run it to work at 5 in the mornig, then when I come back out that evening it will fire right up. It is just after sitting for a while. Especially like after a weekend of lettin it sit around and driving the truck.
Old Jan 3, 2003 | 07:14 PM
No, I'm not talking only about when I first start it up, it does it even when warm. At first I thought it was heat soak, but it did it when it was cold.
385LT1: What kind of carb do you have to automaticly set the choke by tapping the pedal?
Burnout
385LT1's Avatar
cool, do you set the choke by tapping the gas once?
Old Jan 3, 2003 | 07:54 PM
rjmcgee's Avatar
Re: Stumped!
Burnout
If I advance my timing to far it will do something similar. Turn over then act like the battery is dying, then turn over and start. Since you had the distributor out you might check the timing. Just a thought.
Old Jan 3, 2003 | 08:41 PM
385LT1's Avatar
Burnout
A buddy has a Edelbrock 750 with an electric choke....
He tapps the gas once to set the choke.... turns the key and it fires right up into high idle... after sufficient heat in the engine has been built up.... it will kick down...... as they call it....
Old Jan 3, 2003 | 09:10 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
if it worked good before you changed the distributer, i would say your timing is too advanced
Old Jan 3, 2003 | 09:40 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
My choke is not hooked up.
Old Jan 3, 2003 | 09:46 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
You know, I hadn't thought of this, but you have a mechanical and a vaccum advance on there dont you. Have you checked to make sure your weights have not gotten gummed up so they don't advance or you have you checked to make sure you havn't knocked your vaccum line off of the distributer or carb.
Old Jan 4, 2003 | 12:31 PM
philoldsmobile's Avatar
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
on the q-jet (pootah controlled) on my Camaro, i pump 4 times cold and 2 if its been stood for a few hours. hot i just turn the key.
Using this method, it starts first time, and fast idles when cold, right into proper idle warm etc, never any performance or running issues.
On my old Cutlass supreme with 600 holley, 2 pumps and no choke always cold started it.
For the camaro, try 4 or 5 pumps then try starting. i'll wager it fires right up. my car has always been like this, and has no type of fuel leakage.
has yours always been like this?
Old Jan 4, 2003 | 12:32 PM
didn't read other post.
Yup, sounds like a vacumn leak.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
