vortec question
Old Jan 4, 2003 | 05:27 PM
blksc's Avatar
vortec question
Im looking to buy a 87 350 block. im also looking to bolt vortec heads to the it, which means new intake system. I wanted to ask if i could just bolt on a non fuel injected setup with just a vortec manifold and carb instead of the awfully more expensive tpi setup
Old Jan 4, 2003 | 09:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. You just have to deal with the fuel pump issue, that's all.
Old Jan 4, 2003 | 09:54 PM
blksc's Avatar
cool, so whats the fuel pump issue ?
Old Jan 5, 2003 | 09:40 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
fuel injected cars have a high PSI fuel pump. You'll need a return style fuel pressure regulator to bump your fuel pressure down to like 6psi.
Old Jan 5, 2003 | 12:21 PM
blksc's Avatar
cool, can those be purchased for a reasonable price ?
Old Jan 5, 2003 | 12:23 PM
blksc's Avatar
hey 88IROC350TPI
it seems you have done exactly what i want to do with the L98. How hard was the conversion ? So if i remove the tpi setup then what do i do with the computer ? I am looking to put this car in a third gen camaro
Old Jan 5, 2003 | 12:30 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Mallory makes them and you can get them from summit and jegs for around 70 bucks. :lala:
Old Jan 5, 2003 | 12:55 PM
blksc's Avatar
sweet, so once i get that what do i do with the factory computer ?
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
z28addict8490
Sep 5, 2015 03:56 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
