need help with a code 13
Old Jan 4, 2003 | 05:44 PM
19WS6T/A91's Avatar
i just installed headers and now im getting a code 13. the weird part is that the light comes on after about 15 minutes of running then goes off for like 30 then backon for like 15 more minutes. im confused can someone help?
thanks,
david
Old Jan 4, 2003 | 06:26 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
It is your O2 sensor ( Oxygen Sensor ). Did you reinstall it or maybe you forgot to plug it in. You have to be carefull with those thigs to, if you drop them, they will break. Hope this Helps??
Keiran
Old Jan 4, 2003 | 07:46 PM
Vader's Avatar
And make sure the O² is well grounded. Aside from that, headers are often responsible for oxygen sensor troubles since the exhaust gasses cool much faster in the tubing than in a cast manifold, thereby preventing the sensor from maintaining adequate heat to generate a good signal. Many times, a heated sensor is the final solution.
Old Jan 6, 2003 | 11:02 AM
19WS6T/A91's Avatar
i also just realized that the light only comes on while cruising at a constant speed for 15 or more minutes. i can drive around that city all i want and it doesnt come on.
david
Old Jan 7, 2003 | 08:00 PM
19WS6T/A91's Avatar
i know that someone can help me out, i checked the sensor is hooked up.
thanks,
david
Old Jan 7, 2003 | 09:11 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...ht=tpi+code+13
Old Jan 8, 2003 | 11:03 AM
19WS6T/A91's Avatar
thanks for the link, i guess tomorrow i will check and make sure that all of the connections are good. hopefully it just wont be plugged in all the way somewhere along the line. just in case where can i get a heated o2 sensor? would any parts store have this or do i have to order it off the internet?
thanks,
David
Old Jan 8, 2003 | 11:30 AM
Vader's Avatar
Everybody has HO2S - even AutoZone and places like that. They are usually about $50-60 US.
You can "rig" the heaters, or install a relay like this:
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
