A/C removal
Old Jan 6, 2003 | 06:24 PM
CamaroUK's Avatar
A/C removal
If I were to choose to remove the air conditioning unit permanently, would I need to replace it with a free spinning pulley to keep the tension on the belt, or would simply putting on a shorter belt be required?
Old Jan 6, 2003 | 07:09 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
A/C IS a free-spinning pulley UNTIL the compressor clutch engages..until then, it's free. You COULD just get a shorter belt, but if you're running a serpentine system, routing might be tricky since the belt has to run specific sides on specific pulleys. All pulleys EXCEPT belt tensioner and water pump ride on grooved side.
Old Jan 7, 2003 | 09:19 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...+delete+pulley
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
