XE262 lift questions
Old Jan 10, 2003 | 06:22 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Will i be ok using this cam on stock ( no machining done) to the valve guides, the cam has .462/.469 lift, will i have problems with hitting the valve guides? what about with 1.52 rockers? If you need to know the heads are "081" 305 heads. Also i will be buying the cam kit that comes with seals, retainers, locks, timing chain, lifters too.
Kevin
Old Jan 10, 2003 | 06:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Should fit properly, no problems. That's basically the correct way to do it.
Make sure you get self-aligning rockers, if the heads haven't been fitted with guide plates.
Old Jan 10, 2003 | 07:34 AM
Engine: 383, L69
thanks for the quick reply, so ill be ok with the lift and valve guides, i just want to make sure cause this has been on my mind all day and night. thanks
Kevin
Old Jan 10, 2003 | 09:58 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
i just put my XE262 in.
sounds stock.
pulls 15" vacuum @ 700 RPM idle.
Has a collapsed lifter now (less than 100 miles on cam).
runs good otherwise.
I will be putting my blower back on soon, i wonder how it will react to the XE262.
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
