Pontiac 350 Same as Chevy 350???
Old Jan 11, 2003 | 10:43 PM
CR-SuperChevy's Avatar
are they the same?? what are the differences cuz my chev 350 from a 77 impala the cam stripped a lobe so i got it warrentied but all my bearings are f u c e d and its only a 2 bolt main and its gonna cost me 400 canadian to get it all fixed , just the bottom end, and i can pick up the pontiac 350 off a buddy for like 200 bucks could i trow my cam and oil pump water pump manifold and other such parts on it i need to know quick so any help much apreciated
kevin
Old Jan 11, 2003 | 11:00 PM
Vader's Avatar
Assuming it is a true Pontiac design engine, nothing will fit, except for maybe the transmission mounting and the carburetor. Possibly the spark plugs would be the same. The Poncho used a completely different type water pump (more like a Buick), a different oil pump, a different intake that doesn't seal the lifter valley (they used a stamped steel valley pan), a different length block and different journal dimensions (so the cam, crank and just about everything else won't interchange), and different mounts.
Aside from that, you should have no problems with the swap. Really, you can probably get a bone-yard 350 for a few hundred bucks (CD), and running at that.
Old Jan 11, 2003 | 11:13 PM
CrashedMatrix's Avatar
Two Completely different motors.
Old Jan 11, 2003 | 11:18 PM
well thanks for the help so quick guys i dunno what im gonna do.. sigh
Old Jan 11, 2003 | 11:29 PM
what type of cranks will fit into a chevy 350 other than the 350 chev stock crank? just i dont know help?
Old Jan 11, 2003 | 11:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The only parts I can think of that interchange between a Pontiac 350 and Chevy 350 are the distributor module, the coil, and maybe the spark plugs depending on which heads each one has. Other than that, every single piece is different; and I do mean every, single, piece. Water pump, oil pan, intake, fuel pump, cam, lifters, push rods, oil pump, pistons, transmission, motor mounts, everything about the exhaust, and so on... name a piece, I'll bet it's different. The battery even needs to be on the opposite side of the car.
Fix your Chevy 350. That's what you're going to do, I already know it even if you don't. It's by far the cheapest and best thing to do.
The only crank that fits a Chevy 350 is a Chevy 350 one. Cheapest crank on the planet. What's the problem here?
Old Jan 12, 2003 | 09:28 AM
Vader's Avatar
I could be mistaken, but I seem to remember that around '77 the variation in transmission patterns was reduced to only a few, and that the Pontiacs may have the same pattern as the SBC.
It really doesn't matter, since the SBC is the way to go. Unless you're planning to resotore a Pontiac to stock condition, the engine really doesn't have a lot of value. Shop around for the parts you need. A set of bearing shells is only about $55 (CD), and a crank polish or reground cast crank can be had for nearly dirt.
Old Jan 12, 2003 | 09:35 AM
BOP bellhousing = buick, oldsmobile, and pontiac all use the same bellhousing that is different that the chevy small block/ big block bellhousing. The BOP makes a U at the to instead of a point like a chevy.
Old Jan 12, 2003 | 10:11 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
check e-bay they have 350 stuff cheap. I would help you out here but, I only get to the yards on the weakends and shipping would put an end to that quick. besides you could get better cranks new for very cheap.
Old Jan 13, 2003 | 12:38 AM
im gonna pay to get a new crank and put her all back together and build up ma 383 stroker slowly and then drop her in
Old Jan 13, 2003 | 09:20 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
If you're in canada, I'm going to be the lone dissenter and say you should check out that "Pontiac" 350. Reason being, I've heard that Canadian Pontiacs got Chevy engines from several places.
You may find out it's a Chevy 350 in a Pontiac
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
