How do i figure out my compression?
Old Jan 23, 2003 | 03:16 AM
hydrota85's Avatar
When i bought my car i was told that it had a 1978 350 from a camaro that was rebuilt but it was just a stock rebuild and that would make it a 8.5:1 compression. I was told it was a 9:1 compression engine i just want to check and see what one of these is correct. Thanks
Old Jan 23, 2003 | 05:49 AM
ede's Avatar
ede
for an accurate figure you'd need to know the dish/dome volumn, chamber volumn, head gasket thinkness, and the deck clearance, so if the engine is together best you can do is guess or estimate
Old Jan 23, 2003 | 12:05 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Go to www.download.com
You can download engine CR ver1.0
Nice compression ratio calc.
Next you can get an idea of what you have by getting the head casting number. You need to remove one of the valve covers
to see it.
go to www.mortec.com and find your head casting # in the listings.
While there are still unknown variables like piston dome volume
etc. If it turns out you have a cylinder head with smaller than stock chambers, (76cc) your cr will be higher than stock.
Hope this helps, some.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
customblackbird
Oct 1, 2015 04:30 PM
84redta
Sep 19, 2015 09:58 AM
Fronzizzle
Sep 8, 2015 12:10 PM
