Are the accessory mounts the same on pre '87 heads and '87+ heads?
Old Jan 23, 2003 | 09:02 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Basically what is says, are the accessory mounts the same on both sets of heads? If so that would make the only differences the centerbolt and perimeter bolt valve cover setups and the angle of the middle bolts for the intake manifold right?
I want to know if I build a motor with the Stealth Ram could I get pre '87 heads and still mount my current serpentine accessory setup from my '90 motor? Thanks.
Old Jan 23, 2003 | 09:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The actual accessories are differentt, but the bolt holes to mount them should be the same from the early '70's on up.
You're correct, 87 and some 86's, up up, use the newwer style angles...could be that the HSR is ready for both???? Not sure, by Accel Base works for either (Accel claims)
Old Jan 23, 2003 | 10:08 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
youll need to drill + tap one hole on the pass side head to accomodate the bracket. Otherwise, you good to go.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
89mulletbird
Aug 12, 2015 07:08 PM
ZsTransAm
Aug 11, 2015 07:30 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
