Cars Stall need help plz!!!
Old Jan 27, 2003 | 06:04 PM
DMSBRASILEIRO's Avatar
Car: 85 iroc-z
Engine: 350-headers,cam,3"catback
need help plz!!!
hey i have a 85 caramro LG4 it has 225k on it.its all stock except the headers and the problem i got is it idles fine but when i put in drive it stalls even if i floor right after i shift, the only way i can get it to move is if i rev it and just do a neutral drop. do any of u have any ideas to what could be causing this
thanx
Old Jan 27, 2003 | 06:18 PM
Car: 85 iroc-z
anyone????
anyone???
Old Jan 28, 2003 | 09:25 AM
Jza's Avatar
Jza
Try this: Unplug the electrical connector at the transmission and go for a drive.
I'm wondering if your TCC is staying locked up and causing it to stall going into gear. Unplugging the connector will rule that out (electrically anyway).
Does it kinda lug while pulling away and shift rough?
Old Jan 28, 2003 | 12:54 PM
Car: 85 iroc-z
ya it does
Old Jan 28, 2003 | 01:05 PM
Morley's Avatar
One quick way to check the torque converter lock up is to drive the car at a steady speed (50 mph is good) keeping the car at speed, tap the brakes and watch the tach. You should see a momentary rise of a few hundred RPM. Check it several times to be sure. If you don't get the rise in RPM then the converter is stuck in lock up.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
