Anyone heard of Torque Plus Intake Gaskets?
Old Jan 30, 2003 | 07:58 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I was browsing through Jeg's last night and found some intake gaskets called "Torque Plus" that have little mesh screens in them. They are supposed to atomize the fuel and create smaller droplets. Do they work? Anyone tryed them?
Later,
Matt
Old Jan 30, 2003 | 01:32 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I would also like to know if they work.
Old Jan 30, 2003 | 01:43 PM
rezinn's Avatar
Maybe try asking on the carb board if no one here knows.
Old Jan 30, 2003 | 01:49 PM
onebadwagon's Avatar
in my opinion, that is stupid. why would you put a restriction in your intake? if its a poorly designed intake, then i could see some fuel / air separation, but i wouldnt run one of those either.
adam
Old Jan 30, 2003 | 02:04 PM
Morley's Avatar
In cold temps the fuel would form droplets on the screens, in effect doing exactly the opposite of what they claim.
Old Jan 30, 2003 | 02:57 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
Yes, but it should not take long to warm up the intake runner to the point where fuel can no longer condence. They appear in the picture to be very fine mesh screens. I'm not sure if there would be any restriction or not. I'll post on the carb board to see if anyone there has them.
Matt
Old Jan 30, 2003 | 04:49 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I don't see how they would be restrictive they would much less restrictive then any air filter ever made!
Old Jan 31, 2003 | 12:27 AM
ronterry's Avatar
Car: '94 Corvette
May not clog up the first day after there installed, but imagine a couple of months or a year down the road???
It's a secondary air & fuel filter, you can't clean ... ouch ...
Ron
Old Jan 31, 2003 | 07:48 AM
85TPI400's Avatar
Good subject,
Those things seem like they would certainly slow down air and gas flow. Many people with TPI units remove the screens from their MAF sensor because it increases the CFM significantly. I am also willing to bet the screens in the MAF sensors have much bigger holes or are not as fine as the screens in the gaskets.
I would like to hear what other people think about these also!
Old Jan 31, 2003 | 10:54 AM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
If you have a good air filter and fuel filter I don't think they would clog up. Another thing I thought about is that they may save that carb stud nut if you dropped it in the intake. That way you could stick a small magnet down there toget it. I'd really like to know if anyone has used them though, it's the only real way to test strengths and weaknesses.
Matt
Old Jan 31, 2003 | 04:01 PM
if you really want to see, just give them a try, but for me, people have gone really fast without them, so why waste the fourty bucks. i seriously doubt their claims.
adam
Old Jan 31, 2003 | 04:08 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Tehy are capitlizing on an old trick that people did in the '60 some of my dad's hot roding buddies seware buy putting old window screens on the intake and say they they get a noticable boost in power, I don't think it would work in an EFI car though. just my .02
Old Jan 31, 2003 | 05:47 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You might be able to make you own using nylon pantyhose. Somebody try it and tell me the results, because nobody here wants to spends the money.
Old Jan 31, 2003 | 06:30 PM
rezinn's Avatar
While you're putting pantyhose in your engine, you could try shoving a shoe in the intake tract to increase the velocity of incoming air
Old Jan 31, 2003 | 09:56 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Shoe huh, i don't see how that will increase performance, i think it would hurt flow.
Old Feb 1, 2003 | 12:31 AM
i put corkscrews in each of my intake ports to maximize swirl, it was good for fourty horsepower on the dyno.
adam
Old Feb 1, 2003 | 12:50 AM
Marshall89ws6's Avatar
hey why dont we all get together sometime have a few beers... we can throw nuts and bolts down in our intakes and hope we get some power!
Old Feb 1, 2003 | 02:00 AM
OMINOUS_87's Avatar
The only chance of those working is in a poorly setup carb application. As far as any electronic direct port injection motor all those would do is hurt performance. Lets remember here that a fuel injector would be sitting almost on top of the dumb screen as the whole intention is to spray directly into the head and right into the combustion chamber hence taking any instability out of the air fuel mixture that is sometimes developed in carbed motors.
Old Feb 1, 2003 | 02:40 AM
hey marshall, why would we have to have beer?
adam
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
86White_T/A305
Aug 17, 2015 12:16 AM
