ZZ4 cam stats
Old Jan 30, 2003 | 04:29 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
ZZ4 cam stats
Anyone got all the dimensions for a ZZ4 cam .I want to measure one this weekend to see how " used " it is
all help appreciated
:rockon:
Old Jan 30, 2003 | 05:13 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
or at least where to find them ....... tried a search ....... nothing that specific .......... too many posts to read them all
Thanx alot all
Old Jan 30, 2003 | 05:31 PM
joshp14's Avatar
took about 30 secs to fin this in the SEARCH button...
https://www.thirdgen.org/techbb2/sho...hlight=zz4+cam
i had no trouble finding them.
Old Jan 30, 2003 | 05:39 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
HMMMM...... all I got with the words ZZ4 was about the engine ....thnx alot
:rockon:
Old Jan 30, 2003 | 05:53 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Well....I should clarify .........I need the entire lobe dimention . I have the stats of the cam ......I just need to know how to measure this . I am trying to find out how used this cam shaft is . Also how much where can there be before it is really not worth the labour putting it in
would I ...... Take the longest distance ( on the cam profile) and subtract the smallest distance ( therefore giveing me the lift of the cam )
Thanx again
Old Jan 30, 2003 | 06:29 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
lol. If it's 'used' enough to have changed dimensions, then it is garbage holmes. Or more explicitly, you should be able to tell by looking at it if it has taken on abnormal wear. You don't need to measure it, it will either be ugly, or A-OK. Roller cams are pretty good like that. Could make sure it's straight though (just roll it on the pool table)
Old Jan 30, 2003 | 06:56 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
WICKED ......thats all I needed to hear .....thanx ED :rockon:
.....I was going to mic it out and stuff .......( I would have been pretty embarased ) . I dunno the guy ...so I just wanted to make sure the cam was on the up and up
again .....I appreciate the response for a ill tech based member ( but that is why I am hear.... to learn )
Jorlain
Oct 8, 2015 01:57 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
masonta
Sep 1, 2015 06:40 PM
