What's the formula for setting the torque arm angle??
Old Feb 1, 2003 | 12:07 AM
CamaroX84's Avatar
I am going to set the angle on my Spohn adjustable torque arm tomorrow. I forgot what the formula was using the angle finder. Any help would be greatly appreciated. Thanks.
Old Feb 1, 2003 | 12:11 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The driveshaft angle should be equal-to-but-opposite-of each spline shaft.
I.E., if the angle of the driveshaft coming out of the tranny is 10* down, then the angle into the rear end should be 10* up.
This is taking into consideration that the car is planted with all four wheels on the ground, and all the weight of the car is on the springs.
Old Feb 1, 2003 | 12:18 AM
AJ_92RS's Avatar
Shoot......
I forgot about the 2* added for the rear.
There has to be some allowance for the rear end wanting to go upward under a load. This is usually 1-2* extra "below" the tranny angle.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
evilstuie
Feb 28, 2016 03:33 PM
IROCZ1989
Jan 24, 2016 03:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
