Block question, and parts recommendations?
Old Feb 2, 2003 | 09:03 PM
cael's Avatar
How much power is too much power for a 1 piece rear seal 350 block? A junkyard guy near here said he'll sell me a perfectly good 350 block for 100 bucks. Of course, said block would be checked, checked and rechecked before I actually built into it!
I'm leaning towards this setup right now: Eagle crank, Fastburn heads, HotLT4 cam, 1.6rr (Crane Gold?). Pistons & rings, rods and all of the bearings are still up in the air, any good recommendations?
I'd like to peak around 5500 or 6k RPM, with room to go past if necessary. I'm aiming for 400-450 hp (as to hit 500+ with a 100ish shot of haha).
Thanks!
Old Feb 2, 2003 | 09:08 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
the block will work, are you going to run fuel injection? How bout more cam?
Old Feb 2, 2003 | 09:18 PM
cael's Avatar
Oh, yeah. Stealthram intake, efi.
Cam specifics are still lost on me, but when I put the hot lt4 cam with fastburns on my engine in Desktop Dyno the power peaked at a pretty nice spot at a pretty nice level. Like 440 @5500, I think, it's saved on my other computer but I'm feeling dreadfully unmotivated atm :sillylol:
Old Feb 2, 2003 | 09:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'm not sure if you wan to run the fastburns i beleive that they have 220cc runners, not good!!
Old Feb 2, 2003 | 10:14 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say for the most part, you have a decent combo. stick with the fastburns, you'll like them. as for the block, there is no power number that they are limited to exactly, but your combo should be no problem with it. i'd recomend main studs and splaying it if you can afford it. main studs being a minimum.
Old Feb 2, 2003 | 11:00 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Sorry they have 210cc chambers, which is condsidered very large for a street engine.
Old Feb 2, 2003 | 11:33 PM
cael's Avatar
If not fastburns, what would you recommend as far as head/cam for my HP goals?
Also- what are some good brand internals that'll hold that sort of a beating? I've been thinking Keith Black pistons, but honestly I have no clue when it comes to brands of rods, rings, bearings or bolts. Most I've looked at are only advertised for engines "up to 450hp." I'd like to build it stronger than "strong enough" just for security's sake, I'm working on running my 3rd Chevy SB into the ground heh
Old Feb 3, 2003 | 07:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sound just fine to me, except the Stealth Ram won't even cover the ports on the FastBurn heads. Their intake runners are in a different place than older motors (raised - "Vortec" = GM trade name for "raised ports").
A 2-bolt block is fine at the HP level that the Stealth Ram will support, whichi is around 425 HP max. That's well within the block's limits. Keep the RPMs below 6500.
Old Feb 3, 2003 | 10:20 AM
cael's Avatar
Well.
Didn't realize they were vortec!
Glad you mentioned it, that'd have been really sucky..
Jake_92RS
Jan 28, 2020 10:37 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
BBSDesigns
Aug 11, 2015 07:39 PM
1nastygta
Aug 8, 2015 07:38 PM
