Can anyone decode this engine # for me?
Old Feb 3, 2003 | 07:55 AM
LT1guy's Avatar
Car: 1987 Trans Am
Its from the front of the engine in my 87 TA...K0824FJC. The car was originally a 305, but one of the former owners claimed a 350 was swapped in. It runs like a 305, but I'd like to know for sure, and my #s book only covers casting #s and I can't see the casting # with the engine in the car.
Old Feb 3, 2003 | 08:35 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
My engine didn't come up either. I did a search with just the casting # on the net and it pop'd right up.
Old Feb 3, 2003 | 08:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't bother with that one... get the casting #. It can be seen, with a minor amount of effort; it's behond the driver's side head, on teh top of the bell housing flange. It's the one that will tell you with absolute certainty what the motor really is; or at least, what the bore diameter is. Since that's the one thing that sets a 305 and a 350 apart, it's all you need to know.
Old Feb 3, 2003 | 09:01 AM
LT1guy's Avatar
Car: 1987 Trans Am
Thats what I figured...theres a lot of built up gunk in that area, plus a wiring harness, but I'll get it all out of the way tonight. True, 305 vs 350 is all I really need to know...if its a 305, I won't bother doing much to it. The engine code hasn't shown up anywhere I've looked so far.
Old Feb 3, 2003 | 04:12 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Sometimes (depending on gunk) you can crawl under the car and look at the 3 numbers (digits) on the side of the block.
When I bought my truck, that's what I did. Although it's a lot easier to see under a truck than a pass car.
Then go to the good ol' www.mortec.com and match them with the last 3 of the casting numbers listed.
F.I., the numbers on my truck motor are 203.
14010203...305...80-85...2
Old Feb 4, 2003 | 01:23 PM
LT1guy's Avatar
Car: 1987 Trans Am
Cool, I didn't know part of the casting # was there too. I have noticed some late model blocks have the displacement on the side or even the bellhousing flange, but for some reason LT1s say "327"...havent figured that one out yet.
Old Feb 4, 2003 | 01:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
10125327...350...92-up...2 or 4...Gen.II LT-1, reverse flow cooling
Almost makes sense, doesn't it?
Old Feb 4, 2003 | 02:09 PM
LT1guy's Avatar
Car: 1987 Trans Am
THAT number...
I really need to start getting more sleep!
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
