HEADS ???'s
Old Feb 4, 2003 | 10:04 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
HEADS ???'s
My crate 350 came with "stock TBI/TPI" heads. What the heck does that tell me??? Does anyone know the stock stats? The cam that came in it has *203/*210 dur. @.050 and .476/.480 lift.
They are definately not vortec heads. "My stock intake fits". From what I understand vortec heads can only accomodate up to about .450 lift or so. Is that true. I got that info from ScogginDickey Chevrolet. So how can these heads accomodate more lift than the "new" vortec heads???
Old Feb 4, 2003 | 10:25 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
probably the cast-iron l98 heads. You tell tell for sure by getting the casting numbers.
Old Feb 4, 2003 | 10:27 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
didn't think about that.
Old Feb 4, 2003 | 12:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
TBI and TPI heads are completely different. There is no such thing as what you described. So, we know right from the get-go, you could have almost anything. There's no way to do anything more than just guess without a casting number. Get that, visit www.mortec.com or post it, lots of people here will recognize what kind they are and what to do.
Your cam looks alot like the stock L98 cam. Not much of a cam really, but not near as bad as some.
Vortec heads have particularly tall valve guides. It's not like they've been figuring out how to make things easier or harder on hot-rodders; just always remember, they are truck heads, pure and simple. They are meant for trucks, set up for trucks, have parts on them appropriate to trucks, and that's as far as the factory has ever carried them. They do not come set up as a performance head, for things like high-pressure springs, or high-lift cams, or any of that; they're truck heads. Lots of older heads will accomodate more lift than those truck heads.
Old Feb 4, 2003 | 04:27 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
That is way too much lift for an L98 cam.
Old Feb 4, 2003 | 05:36 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
The cam is a LT4 cam and here is the engine spec sheet. Check out the head information. See there is such a thing.
Price: $2,495.00
Part # SD300TBI
Horsepower: N/A
Torque: N/A
Compression Ratio: 9.6:1
Duration @ .050" I/E: 203°/210°
Lift I/E: .476"/.480"
Block: 2 Bolt Main Goodwrench - 1 Piece Rear Seal
Crank: LT4 Nodular
Heads cc: Stock TBI/TPI
Intake: N/A
The original spec sheet claimed 300HP for this motor.
Old Feb 4, 2003 | 05:51 PM
Momar's Avatar
Price: $2,495.00
Part # SD300TBI
Horsepower: N/A
Torque: N/A
Crank: LT4 Nodular
Intake: N/A
No, there is not a such thing. For one thing it says head cc. That is a measurment. That could mean that they have the same size combustion chambers or same size intake runners or something of the sort, but it does not say that it is the same casting number as the tpi/tbi heads because they didnt have the same heads.
Ben
Old Feb 4, 2003 | 06:00 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I know I know. I am just saying what are the specs ya know why do they give me a spec sheet with that on it? I am going to have to get the numbers off the heads.
Ok I just went out to get the numbers. Aren't they suppose to be on the back of the casting? Can't find them.
Old Feb 4, 2003 | 06:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Head casting #s are under the valve cover, between rockers. The block casting # will be on the top of the bell housing flange behind the driver's side head.
Old Feb 4, 2003 | 06:11 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I think it means that they could be TBI or TPI heads, it's just whatever crap they had, they throw on. Get some #'s then you will know!
Old Feb 4, 2003 | 06:12 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Well, I guess I won't be getting those head numbers tonight then . I was thinking about the block numbers. Thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
