my car won't start. help!
Old Feb 6, 2003 | 02:40 PM
knightjacob's Avatar
My car won't start (again). It was running fine, and I drove to pick up some food and then it wouldn't start again. It cranks, but won't start so now it's sitting in a chinese restuaraunts parking lot. It's TBI. I was looking at it this morning and the injectors aren't spraying and fuel. I has plenty of gas in it. WHat could it be??? I'm thinking it's the fuel pump, it has a new filter, could it be anything else???? Thanks
Old Feb 6, 2003 | 03:00 PM
rezinn's Avatar
Do you have adequate fuel pressure? Is the pump priming? The computer won't fire the injectors unless it recieves reference pulses from the distributor, so that's another possiblity.
Old Feb 6, 2003 | 03:08 PM
rezinn's Avatar
What's with the boards? I responded, and I can see my post.. but it isn't showing it from the main board. Does everyone see two posts by me right here?
Old Feb 6, 2003 | 03:34 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
nah the board display isn't working right.
Sounds like the fuel pump is dead.
Old Feb 6, 2003 | 03:42 PM
383 rocket bird's Avatar
I second the fuel pump issue.
Old Feb 6, 2003 | 10:18 PM
Capt.ShadeTree's Avatar
pump?
pump should come on and prime for 4-7 seconds and hold 40 lbs pressure. once pumped, you should be able to turn it off, and still hold that pressure. If not the regulator may be bad. You can pull the vacuum hose to the regulator and look for gas in there too.
also the pump needs to pump a volume of fuel...2-3 pints in 20 seconds I think. you should be able to break the lines under the hood.
is it hard to start cold, or just hot?
Don
Old Feb 7, 2003 | 12:24 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
if you are getting fuel pressure and no injector firing, then check the module underneath the distributor cap. Most auto parts stores can test them.
Old Feb 7, 2003 | 07:24 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Out of curiosity, what state are you in, how much gas in the tank, and how cold was it?
Old Feb 7, 2003 | 07:48 PM
vwdave's Avatar
Before you change your fuel pump, check the fuel pump relay. If you have a service manual, it should tell you how to test it. *By jumping the fuse box.*
Old Feb 8, 2003 | 10:18 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by vwdave
... *By jumping the fuse box.*
You mean for him to put 12V to the 'G' terminal of the ALDL from the fuse box right?
Thanks to Vader for the pic:
Old Feb 8, 2003 | 10:22 AM
vwdave's Avatar
The way I do it on VW's is by hooking the powerlead of that relay to the ground within that relay's position. I am not 100% sure if GM did it the same way. I dont have my manual with me to really check, or I would give you a definate answer.
Old Feb 8, 2003 | 10:40 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Oh, I see, you want him to test the actual relay. I posted how to test the pump (to make sure that was good to go). My bad.
Old Feb 8, 2003 | 10:54 AM
vwdave's Avatar
Its kinda a double test. If the pump doesn't turn on, and it does with the jumper on, change the relay and see if that helps.
If it doesn't turn on either times, check the power and ground leads with a test light to the box and go from there.
If it does turn on both times, relay is good, check fuel pressure.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
86Base
Aug 8, 2015 01:34 PM
