Map Sensor Questions?
Old Feb 8, 2003 | 03:24 PM
mylittlemule's Avatar
Car: 87 Wrangler
Engine: 355 TBI
Last night while driving the mule I was pinching the vacuum line to the Map Sensor and there was no change at all. Should any thing happen when i cut the vacuum to the sensor? I thought that the Map sensor readings corresponded to a fuel and timing map in the ECU. Also, where can i find voltage values based on vacuum readings to further investigate the cause of the major malfunctions?
Thursday i changed my intake gaskets and while inspecting them i found two oval carbon buildups on the gasket from the EGR passages. Are the EGR passages supposed to blocked going into the head or is that normal? I used fel pro 93318 and 93317 gaskets.
And while putting the intake back on i stripped the first intake thread again. DOH
Old Feb 9, 2003 | 12:20 PM
Car: 87 Wrangler
Engine: 355 TBI
Need help guys. Today is a beautiful day and i have it off. Must work on the Mule. Please Help:hail:
Old Feb 9, 2003 | 02:05 PM
Vader's Avatar
Normally, you could search the archievs and get a lot of information, but...
Whip out your handy digital meter and vacuum gauge/pump. Test the sensor voltage output and compare it to this scale:
Old Feb 10, 2003 | 07:22 PM
Car: 87 Wrangler
Engine: 355 TBI
Thanks Vader, on both parts. As soon as i saw the graph, i realized I already had it in my archives of photos. Anyway, not I do not have any more excuses.
Right On
Eric
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
