High BLM's
Old Feb 8, 2003 | 07:03 PM
breathment's Avatar
High BLM's
installed a new 4 wire O2, but Im not sure the O2 was all of my problem. but then again i am starting to get confused on this whole BLM crap.. i don't understand how i can have O2 readings of .7 or so and still have a BLM of 160. i wish i could understand all this better but im trying.. because the O2 readings seem to be higher, but the BLM's aren't.. maybe it hasn't been driven enough to get the BLM's lower?
the second link has a WOT run near the bottom, detonation isn't that bad this time.. i have a few theorys that i wanna check out.. but i want to learn more about these readings and stuff.
at least the O2 mV is higher at idle then it was before. not by much but its something.. but im not even goign to go into the other problems i was having tonight with voltage and the IAC..
dang fbody.com limiting file size to 200K.. the second file is alot longer originaly..
http://www.fbody.com/members/david88...ruise_stop.htm
http://www.fbody.com/members/david88...ruise_wot2.htm
(these emissions and scan readings were taken at the same time)
http://www.fbody.com/members/david88.../600rpmrun.htm
600 RPMs
CO --> 1.50%
HC-->297 ppm (this is way down from before)
NOx--> 13ppm
Co2 --> 9.75%
O2--> 3.90%
http://www.fbody.com/members/david88...2000rpmrun.htm
2000 RPMS
CO-->0.09%
HC-->80ppm
NOx-->43ppm
Co2-->8.49
CO-->4.49
O2 is new,
EGR is new,
Plugs are old (see this post --> https://www.thirdgen.org/techbb2/sho...hreadid=159718 )
Injectors were sent to Cruzin Performance for service.
My cold idle problem started after installing the new EGR and putting the injectors back in..(see this post --> https://www.thirdgen.org/techbb2/sho...hreadid=155365)
the main thing i want answered (cause i know i wrote alot) is what you can tell me about the scan data\emissions data and the plugs.. thanks
Old Feb 8, 2003 | 07:06 PM
breathment's Avatar
oh and one more thing. i found this tonight. its getting replaced tomorrow with stock that a friend is burning for me. think it can have any impact?
Old Feb 9, 2003 | 12:03 PM
breathment's Avatar
top
Old Feb 9, 2003 | 09:58 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I am noticing your MAF flow rate, at idle on my bone stock L98, I would pull 8-9 gm/sec and at 2000rpm with a 1v TPS voltage, I would flow 50 gm/sec, but my injector pulse rate is alot longer. It could be because you were on the dyno. Do you have any scans of you just driving on the street, the other fbody.com links don't work. My plugs looked just like yours when I had a blown intake gasket, my BLM would go to 160 and my o2 would drop to 4 before I fixed that.
Old Feb 9, 2003 | 10:09 PM
breathment's Avatar
i fixed the first two links..
hmm well my vaccum is about 18" that is pretty steady but will kinda move back and forth very slowly about an inch or two that goes along with engine speed. i had a video of it, but its not working...
Old Feb 10, 2003 | 12:06 AM
breathment's Avatar
ok after using the stock chip here are the readings..
WOT run
http://www.fbody.com/members/david88...antool/wot.htm
Cruising and accelerating
http://www.fbody.com/members/david88...l/moderate.htm
Old Feb 10, 2003 | 12:31 AM
Were your BLMs this high before you did your EGR and injector swap?
Old Feb 10, 2003 | 12:38 AM
Z_Ghost's Avatar
Next time you get time spray some WD40 around the injectors and see if the rpms change.
I am really starting to think that you are getting air into the motor that the MAF is not seeing.
Old Feb 10, 2003 | 04:06 PM
breathment's Avatar
sprayed some starting fluid near the injectors and lower plenum area where the runners bolt to the base. (tried to concentrate most of the spray on the injectors where they go into the base)
and as you can see i do have a slight leak. well i guess its slight, i don't really know how bad of a leak it is. but since i have around 18" of vaccum it can't be too bad can it? this graph shows the RMPs rise when i sprayed the starting fluid near the injectors on both sides and trying some other areas along with the O2 mV. the whole graph takes place over about 7 and a half minutes. i wonder how bad of a leak i do have...
oh and this was all done with the IAC unplugged
EDIT: ok now i am as confused as a Mexican in a Chinese McDonalds.. the BLM's throughout this graph were at 128 in Cell 1 the WHOLE time EXCEPT when i sprayed the starter fluid. when i sprayed the starting fluid the BLM cell would goto 2 and the BLMS went to 126.. other then that they stayed at 128 and didn't move at all.. i don't see how i could be running at 128 unless maybe it had somethign to do with the IAC not being connected and it was screwing things up? it said i was in closed loop
EDIT2: hmm i just noticed something else VERY interesting... my usual closed throttle TPS voltage is .71 (i adjusted minumum air and had opened the throttle some and forgot to change the TPS voltage). but when i did the vaccum leak test i had unplugged the IAC but it didn't close all the way (yes i did the correct procedure to close the IAC) so i had to back the throttle adjustment screw out all the way and the idle wouldn't go below 1000 but the voltage was .57 instead of .71.. maybe that had something to do with it...
Old Feb 10, 2003 | 05:19 PM
rezinn's Avatar
The base tps reading relies on the IAC adjustment, that's why you adjust the IAC before doing the TPS. If you moved the minimum air position and the TPS voltage changed, that's normal.
Did you install the o-rings for your fuel injectors dry?
Old Feb 11, 2003 | 04:03 AM
Z_Ghost's Avatar
Next time try cutting the pic down some, it's hard to read when I have to scroll right and left all the time.
OK it is easier to read when I am replying.
So did you put them in dry?
You should not get any reaction at all, that says that you have a vacuum leak, even a small one can cause problems.
You do need to clean and replace that IAC, fix that and the vacuum leak.
The IAC is a vacuum leak, the computer know how far it wants it opened or closed and calculates that air getting into the motor, if it's not going were the computer tells it to then that throws things off.
Get them fixed and we can see how it runs after that.
Old Feb 11, 2003 | 03:47 PM
breathment's Avatar
sorry, I use such a high screen resolution that it shows up without having to scroll. i forget that most people use 800X600 while i use 1024X768..
i think i might have, i know that i added oil to the upper o-rings but but it started to rain when i was working on getting them into the base so i don't think i did. and i didn't think anything of it until after i had the plenum bolted on for the last time and i hoped that they came with enough oil from Cruzin Performance that it wouldn't effect it. but i guess maybe that is not the case. well it looks like i will doing that this weekend. do u have to pull ur runners to get the fuel rail off? oh well they need to be polished better anyways..
ya but still at least that air is metered through the MAF though right? i was gonna take it off today in School to clean it, but we had ANOTHER day of cleaning the shop. i might try to get to it later today.
thanks:hail:
sp8ty
South East Region
Sep 24, 2018 03:55 PM
Mark_ZZ3
May 24, 2018 01:02 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
