Replacing an Ignition Switch
Old Feb 9, 2003 | 10:56 PM
FLYNLOW92rs's Avatar
So what am i in for?
I'm buying one from Discount Auto tomorrow and attempting to install it...
So anyone install one before??.....Tips, how long it takes, ETC.....
Any help is appreciated...
FLYNLOW92rs
Old Feb 10, 2003 | 01:35 AM
ramrod85's Avatar
Car: 85 Z28
Engine: 350/ 290hp EZ-EFI
Axle/Gears: 3.08 posi
Getting the steering wheel off is about the only problem. Disable the airbag first. (Very important)
Old Feb 10, 2003 | 08:57 AM
So i have to take the steering wheel off??
The ignition switch is on the back of the steering column, does it have to do with the rods??
I have the steering column dropped and can reach it, it looks like the steering wheel won't block me from dong anything...
Old Feb 10, 2003 | 09:07 AM
Vader's Avatar
You shouldn't have to remove teh wheel unless you have a problem with the linkages or lock cylinder. Just remove the two screws holding the switch. Be very careful not to move/drop the linkage rod. You may want to wrap a piece of masking tape around the linkage rod and outer jacket of the column to hold the rod in place while the switch is off, just to be safe. It may be possible to swivel the rod just wrong and have it fall out of the linkage at the tilt mechanism, which turns the switch replacement into a major project.
Old Feb 10, 2003 | 11:21 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Are you trying to replace the ignition switch or the lock and tumbler?
Old Feb 11, 2003 | 02:41 PM
mattRS's Avatar
after you have dropped the column, go ahead and take off the brace that is on the bottom of the column. gives you more space. dont take your keys out of the ignition while you are doing it, since that will change the position of the part that the rod goes into on the switch. to get the back rod out, slip a flathead into the LITTLE hole on the back where that rod goes in. the directions dont say where to put it in, so thats just a little heads-up. hope you have skinny hands too!! you need anything else, lemme know. i did this last week.
Old Feb 11, 2003 | 10:14 PM
ramrod85's Avatar
Car: 85 Z28
Are you sure it is the switch. On mine this piece snapped. When you turned the key the rod attached to this piece would not actuate the starter switch. If you have to go into the top of the column, you might as well tighten up the torx bolts on the tilt mechanizm. Here is a good site for info on GM tilt columns.
Old Feb 11, 2003 | 10:15 PM
ramrod85's Avatar
Car: 85 Z28
Oops. Here you go http://home.t-online.de/home/O_Scholz/steering.html
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
